Author: Subject: toyota supra turbo engine
hootsno1
posted on 27/5/10 at 11:24 AM Reply With Quote
hi all has anyone used the toyota supra turbo engine in a 7 style car befor, i have the chance to buy one thats been flattend at the rear by a lorry for the sum of £500 for the hole car the engine will be going in a mk indy hopefully once i move and have my garage. v soooooooooooon
matt_claydon
posted on 27/5/10 at 11:33 AM Reply With Quote
Welcome to the forum; I did see one in a Seven of some sort (perhaps a Velocity) a couple of years back, no more detail than that though I'm afraid.
indykid
posted on 27/5/10 at 11:43 AM Reply With Quote
they're INCREDIBLY heavy
it may fit, but it would be no fun to drive
tom
tegwin
posted on 27/5/10 at 11:51 AM Reply With Quote
This was discussed recently... they are very tall apparently... plus have a wide bellhousing....
By my classic TVR and stick the engine in that... would make much more sence! (replacing the cast iron TR6 engine!)
www.verticalhorizonsmedia.tv
franky
posted on 27/5/10 at 12:16 PM Reply With Quote
A little heavy but it'd be a good engine choice for mahoosive BHP
jimgiblett
posted on 27/5/10 at 12:54 PM Reply With Quote
If it is a manual I think you would be better off attaching it to a Lexus V8 and then sell off the engine etc.
In my opinion a bit chunky for a 7. Better in a Cobra or Scimitar
- Jim
rost
posted on 27/5/10 at 02:31 PM Reply With Quote
The guy from whom I got my SR20 had one of those engines too. They're not just huge, they're massive! The bigger power output compensates for the weight, but I don't think there'll be any room left for you to sit in the car. Same goes for the RB26DETT, great engines but just too big to fit in any car. You'll need room for a bigger radiator and intercooler too.
[Edited on 27/5/10 by rost]
Charlie don't surf!
bimbleuk
posted on 27/5/10 at 02:58 PM Reply With Quote
Yep quite tall and long but it's all the cast bracketry and turbo gubbins which make them both heavy and bulky. I think you'll find either the 2JZ-GTE or the earlier 7M-GTE will be over 200kgs for the engine and gearbox.
I'll stick to my 5.7 litre all alloy LS1 V8. Which just dips under 200kgs with the huge T56 gearbox attached.
RazMan
posted on 27/5/10 at 03:49 PM Reply With Quote
I've got that engine in my Toyota Soarer - really easy to get 400bhp+ with just a few tweaks. Rather bulky in a Seven I would have thought
Raz
bhp
posted on 2/6/10 at 07:01 AM Reply With Quote
A friend of mine has that engine in his kit car I"m sure it"s in a luego chassis. It is alot larger that my westfield when its next to it...
The engine is being rebuilt at the moment and should see around the 650 bhp mark.
Strontium Dog
posted on 2/6/10 at 07:59 AM Reply With Quote
IIRC at one point Toyota used the 3SGTE in the Supra when racing as the Supra engine is too big and heavy causing the cars to go straight on in bends!
3SGTE from an ST205 (Celica) or 215 (Caldina) is an easy 300hp all day every day and lots more if you want to forge the motor!
