adrianreeve
| posted on 7/6/10 at 06:16 PM |
Do I need washers under my flywheel bolts?
My engine came with no flywheel, and now I'm putting one o , I'm not sure whether or not there were washers under the bolts. Can anyone
tell me?
Adrian
designer
| posted on 7/6/10 at 06:18 PM |
Every bolt needs a washer under it.
r1_pete
| posted on 7/6/10 at 06:22 PM |
The Zetec I built a couple of years ago didn't have any, just a dab of threadlock and torque up.
Not true for all engines, some have lock rings, can't remember seeing one with washers though??
RAYLEE29
| posted on 7/6/10 at 06:24 PM |
Id have to disagree,
definately no washers under my main cap bolts or big end nuts and im going to check the flywheel for you now back in 5
Ray
adrianreeve
Excellent, a yes and a no! Anyone else know?
Adrian
adrianreeve
Too slow to reply!
Cheers Ray, that'd be great!
[Edited on 7/6/10 by adrianreeve]
mcerd1
| posted on 7/6/10 at 06:26 PM |
what engine is it ?
adrianreeve
| posted on 7/6/10 at 06:27 PM |
Sorry, it's a silvertop 2litre Zetec, for some reason, just assumed everyone would know what engine I had!
RAYLEE29
| posted on 7/6/10 at 06:29 PM |
definately none on my pinto flywheel
Ray
Danozeman
| posted on 7/6/10 at 06:30 PM |
A zetec has NO washers. I have never seen washers under any flywheels bolts. TBF the only bolts in an engine i remeber seeing washers with are head
bolts and not all of them have washers.
Dan
flak monkey
| posted on 7/6/10 at 06:31 PM |
Definately no washers on flywheel bolts!
Sera
http://www.motosera.com
adrianreeve
| posted on 7/6/10 at 06:34 PM |
Cheers guys!
snapper
| posted on 7/6/10 at 06:36 PM |
No washers......
But do use ARP bolts and thread lock for that extra safe feeling as you will (eventually) rev the nuts off it.
ARP bolts are about £16 of eBay and very strong.
I also added a dowl for extra security.
I eat to survive
I drink to forget
| posted on 7/6/10 at 07:45 PM |
no washers on crossflow flywheel nor cylinder head bolts.
Canada EH!
| posted on 7/6/10 at 10:10 PM |
Ususally washers on Ali to prevent galling when torquing
Bluemoon
| posted on 8/6/10 at 10:34 AM |
You would normally use a washer under a bolt (it's good engineering practice) but there are always exceptions.. Do as ford do to be safe...
Dan
