<<  1    2  >>
Author: Subject: Engine choice = reliability
AndyW
posted on 15/6/10 at 05:27 PM Reply With Quote
Although Im a little way off getting the engine, I thought I'd ask as to the pro's and cons of 4cyl engines.
I like the vauxhall redtop.
I dont want bike engine.
I want reliability and good speed.
Any suggestions to anything other than the vauxhall lump and pro's and con's to them. I am also like many many others on a tight (ish) budget.
Any advise on engine options and choices welcome.
Thanks in advance.
blakep82
posted on 15/6/10 at 05:30 PM Reply With Quote
there's vauxhall ecotec and ford zetec and duratec. don't know the pros and cons between them all, but
ecotec is same block as red top, slightly down on power, but newer, and more of them available so cheaper. type 9 fitmaent is dead easy.
________________________
AndyW
posted on 15/6/10 at 05:33 PM Reply With Quote
how "easy" is type 9 fitment to vauxhall ecotec?
big-vee-twin
posted on 15/6/10 at 05:38 PM Reply With Quote
Get your self a 2.0 ltr Duratec, nice light weight aluminium engine and relativity easy to get 200 BHP.
It also has timing chain not rubber belt for that extra piece of mind -loads of tuning parts available
http://www.triangleltd.com
blakep82
posted on 15/6/10 at 05:39 PM Reply With Quote
bell housing from yukspeed. done.
omega0684
pinto
con slightly heavier than a ecotec, pro = a bomb proof engine!
Stuart_B
posted on 15/6/10 at 05:45 PM Reply With Quote
duratec engine, as said light weight, good power, just a bit more cost than a zetec to do, but well worth it
stuart
speedyxjs
Duratec or forget the 4 cylinder and go for 6
philw
I have to agree, if i was to do it again it would have to be a Duratec, light all alloy easily tunable, a lot of rally boys i know are using it and moving away from redtops simply for the fact it's newer, the redtops still a damn good engine though.
Must try harder
graememk
posted on 15/6/10 at 05:48 PM Reply With Quote
nissan 200sx
ca18det already rwd and come with a gear box
[Edited on 15/6/10 by graememk]
franky
posted on 15/6/10 at 06:00 PM Reply With Quote
I'm biased but for £1500 you can get a 300bhp as standard m3 lump and gearbox. engine is the same weight as a red top, gearbox is lighter than a type 9 etc.
For £400 you can get a 328i engine and box which makes 220bhp with £80 worth of mods lighter than a red top.
whitestu
posted on 15/6/10 at 06:01 PM Reply With Quote
If on a budget a Zetec is hard to beat.
Mine cost £55 for a low mileage 2.0 plus £250 ish for ignition and carbs= around 150 BHP.
Bolts straight up to a type 9.
If I wasn't being tight i go Duratec though.
bimbleuk
posted on 15/6/10 at 06:08 PM Reply With Quote
I would say a Toyota 4AGE and preferably the later 20V engines and leave them be as they are great engines in standard form with ITBs as standard. However the conversion kit to convert to the type 9 can bump up the price. The toyota RWD boxes can be hard to get as well for easonable money.
Silly answer - How about about a Chevy L92 which is a 6.2L V8 with DoD (displacement on demand). On light cruise the engine management alternately shuts of cylinders so the engine effectively runs as a 4 cylinder. Oh and not cheap to buy either so just ignore.
norfolkluego
posted on 15/6/10 at 06:42 PM Reply With Quote
Got to agree, Zetec has to be the best budget engine although you can double (and a bit) Whitestu's estimate if you're going to fit a decent exhaust manifold
[Edited on 15/6/10 by norfolkluego]
whitestu
posted on 15/6/10 at 06:49 PM Reply With Quote
Good point! I knew I had forgoton something. The same cost applies to the other choices too, except possibly the Nissan 200 engine.
I did mine on the cheap by fitting a secondhand Westfield CVH manilfold.
Stu
[Edited on 15/6/10 by whitestu]
lotusmadandy
posted on 15/6/10 at 07:05 PM Reply With Quote
I agree with the zetec route.
I paid £50 for my 60,000 mile 2.0 silvertop,then £200 for the exhaust and £150 for the carbs and jolt.A home made inlet and job done.
£400 for the install,thats on a budget.
eddie99
posted on 15/6/10 at 07:10 PM Reply With Quote
Zetec or Duratec, prob best duratec, as i've spent lots on my Zetec
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
franky
posted on 15/6/10 at 07:23 PM Reply With Quote
the other good point about the 328 lump is its 220bhp on standard injection and without taking the motor apart so you get factory reliability along with the noise a straight 6 makes
SeanStone
posted on 15/6/10 at 07:54 PM Reply With Quote
I'd go Duratec or S2000. M3 lump would be great if you were building an AGM WLR
mcerd1
posted on 15/6/10 at 08:07 PM Reply With Quote
sticking to any pre 95 engine will save you the need for a CAT to get through the test - but even that isn't a massive problem
depends what you want from the engine really - personaly I'm a fan of the big old iron lump running on carbs
yes but did you have to, my pinto was free - then I went mad and spent more than duratec money on it
MakeEverything
posted on 15/6/10 at 08:13 PM Reply With Quote
Cosworth V6.
£150 with 200hp out of the box.
Fits a type 9 with an alloy bellhousing, and has poo loads of torque and power capabilities.
Not good if youre short on space though it is 60 degree V not 90 degree so its fairly slim for a V6.
Kindest Regards,
Richard.
big_wasa
posted on 15/6/10 at 09:17 PM Reply With Quote
Zetec mines on the standard ecu.
Its cheap.
Its reliable.
It needs no maping.
I think I can get 150bhp at the fly and thats plenty for me. 150 horsses @ 550kg should be plenty
dlatch
posted on 15/6/10 at 09:22 PM Reply With Quote
cheaper option= zetec
more expensive= duratec
the duratec is easily the better engine but a zetec is more than a enough for most people in a light weight kit plus if you blow it up a replacement is cheap and easy to find
AndyW
posted on 16/6/10 at 05:08 PM Reply With Quote
thanks for all the reply's. Now all I have to do is find a zetec 2.0 for £50
dlatch
posted on 16/6/10 at 09:32 PM Reply With Quote
no no no you got that wrong your mean't to say "i have decided on a turbo charged duratec" then we can follow along with the build and drool
<<  1    2  >>
