Author: Subject: Zetec inlet?
rich201283
posted on 17/6/10 at 07:43 AM Reply With Quote
Zetec inlet?
Which zetec inlet can i use, the standard plastic inlet fouls the steering, but i dont want it to stand above the engine.
posted on 17/6/10 at 07:57 AM Reply With Quote
Phew, big Q.
What induction you going to be running?
Keeping the injection, going TB's or carbs etc...
Which ECU? Ford one or other??
rich201283
posted on 17/6/10 at 08:02 AM Reply With Quote
I am going to use the mondeo ecu and may upgrade to megasquirt at a later date, I have got bike carbs at the moment but im having 2nd thorts about usining them
doddy
posted on 17/6/10 at 08:03 AM Reply With Quote
you can use this
http://cgi.ebay.co.uk/RWD-KITCAR-FORD-ZETEC-2-0-1-8L-RACE-PLENUM-CHAMBER-/320400527211?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash= item4a995c0f6b
or convert to bike thottle bodies or spend lots on other after market kits
austin man
posted on 17/6/10 at 08:13 AM Reply With Quote
if its the silver top you may find that the oil filter also fouls your steering I had to modify the steering on an MK indy and a locost to get round this
rich201283
posted on 17/6/10 at 08:24 AM Reply With Quote
Hi, Yea the oil filter did foul the steering, I got away with this by putting an Alfa Romeo oil filter on as its quite short
Doe anyone know if its possible to fit the sierra efi gear and inlet? Would this work?
[Edited on 17/6/10 by rich201283]
r1_pete
posted on 17/6/10 at 09:13 AM Reply With Quote
Have a look at this thread:
http://www.locostbuilders.co.uk/viewthread.php?tid=138100
austin man
posted on 17/6/10 at 10:01 AM Reply With Quote
brother in law has gon for bike carbs as throttle bodies and kept the injection. Not sure whether the blacktop inlet is a different size. You could also look at the rover turbo inlet and plenum
eddie99
posted on 17/6/10 at 10:49 AM Reply With Quote
I've used a plenum very similar to the one griffin power sell... Maybe something along that lines if you plan on using original ford throttle body. Don't think you will be able to get ECU to run with bike carbs.
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
big_wasa
posted on 17/6/10 at 12:09 PM Reply With Quote
You will if you use an air box with a Maf stuck on it. Will also need ford Tps .
A lot of bother though.
[Edited on 17/6/10 by big_wasa]
