Bluemoon
| posted on 1/7/10 at 08:52 AM |
EP90 GL4 or GL5 in serria diff?
Hi All,
As title, I think I have EP90 GL4 in my diff, should I change to EP90 GL5 (it's going to be fun getting the oil out so I would rather not unless
I have to!)?
Dan
flak monkey
| posted on 1/7/10 at 09:25 AM |
GL5 is the correct spec for the sierra diff and GL4 for the type 9 gearbox. Anything from 75w to 90w either straight or multigrade is fine.
GL5 contains stuff which attacks the brass synchro rings in the T9 over time which will lead to rubbish gear changes.
Sera
http://www.motosera.com
Bluemoon
| posted on 1/7/10 at 11:04 AM |
So can I stick with the GL4 EP90 or should I change? sounds like I should be o.k?
flak monkey
| posted on 1/7/10 at 11:11 AM |
It should be GL5 really - but probably wont make much difference TBH
Sera
Bluemoon
| posted on 1/7/10 at 02:21 PM |
Cool, no rush to change then probably do that with engine oil change latter in the year once I have figured a way to suck the oil out!
Dan
