madteg
| posted on 10/7/10 at 10:20 AM |
Blown engine
Just bin out for a blat seventy mph loud puff loads of smoke in mirror, now running on three cylinders. Looks like head gasket has blown from
cylinder to outside of head, i have never seen this before now going to strip it down.
MkII
| posted on 10/7/10 at 10:28 AM |
Ive seen head gasket failure between no. 4 cylinder and outside of head/block on landrover deisels, not that this help you much but just thought
I'd let you know and in my experience just a case of check head for true and replace gasket. youl be back on the road by tea time . .m.
hobbsy
| posted on 10/7/10 at 11:58 AM |
Head gasket is better than a rod out the side or a holed piston
Always look on the brightside!
madteg
| posted on 10/7/10 at 12:27 PM |
There is two inch missing out the front of head gasket, me very happy now easy fix and no sighns of detonation on pistons will be back on road soon.
Mal
| posted on 10/7/10 at 02:44 PM |
A question for Teg
A little off your head gasket problem, but your listing says you are building a stainless steel chassis. Is this the one you now have on the road? If
so have you had any of the problems that folk say will arise from using stainlessfor chassis construction?
Mal
Stuart_B
| posted on 10/7/10 at 07:04 PM |
not to bad then kev, hope you get it sorted soon.
stuart
madteg
| posted on 10/7/10 at 07:19 PM |
This has a stainless chassis had no problems what so ever bin on road four years now done eleven thousand miles. All tig welded by coded welder
[Edited on 10/7/10 by madteg]
hobbsy
| posted on 11/7/10 at 06:13 PM |
And its nice and shiny!
