Author: Subject: Bolt holes on bottom of carbs
Miks15
posted on 14/7/10 at 11:13 AM Reply With Quote
Im using a set of GSXR600 carbs, and wanted to add a bracket to give them some support from underneath so theyre not just held on with the mounting rubbers.
There are 4 M8 bolts hole (one under each carb). What are these for? can i use them to bolt a bracket too?
I also need to use this bracket to secure fuel lines and electric cables too aswell as the throttle cable adjuster.
Mikkel
cloudy
posted on 14/7/10 at 11:37 AM Reply With Quote
Will be drain holes for the float bowls - they usually only seal when they bottom out the thread (not the head) so not really usable for mounting
www.warnercars.com
Miks15
posted on 14/7/10 at 11:58 AM Reply With Quote
why would drain holes be threaded?
Sorry if its a stupid question
cloudy
posted on 14/7/10 at 12:24 PM Reply With Quote
Because that bolt is what seals the drain hole off
www.warnercars.com
RAYLEE29
posted on 14/7/10 at 12:38 PM Reply With Quote
could be holes for heaters (mine have them) you dont need the heaters so you could use the holes as described
a piccy might help
Ray
Miks15
posted on 14/7/10 at 01:25 PM Reply With Quote
hmm ok, will try get a pic when i get home this evening
