Author: Subject: V6 24v COSWORTH (BOB) Engine
m0csi
posted on 13/8/10 at 12:44 PM Reply With Quote
If anyone can help ...
I am dismantling Granada Scorpio Ultima which has the V6 24v Cosworth (BOB) engine this engine is going in my locost. Looking at the various pipes I am thinkng will I need all these ... anyone put the V6(BOB) in a Locost ... The air con I have taken off ... and generally what will i need to keep ... Hope someone can help ... Mike in Oldham ...
bob
posted on 13/8/10 at 01:19 PM Reply With Quote
Chippy on here has fitted the BOA version in his locost, might be some info in pictures in his archive.
RAYLEE29
posted on 13/8/10 at 02:01 PM Reply With Quote
Hi, I think its the same as in a mondeo v6 in wich case If your planning on using the original injection system youll need the ecu and loom and the reader thing on the column and the transponder in the key.
the transponder on the key is matched to the ecu and read by a ring thing around the ign barrel.
if your using a different column you can carefully remove the transponder from the key and tape it to the reader.
Ray
[Edited on 13/8/10 by RAYLEE29]
zilspeed
posted on 13/8/10 at 04:01 PM Reply With Quote
It isn't.
RazMan
posted on 13/8/10 at 05:19 PM Reply With Quote
Originally posted by zilspeed
It isn't.
Ditto - that's a Duratec V6
Raz
mcerd1
posted on 13/8/10 at 05:38 PM Reply With Quote
this might have some info for you: http://www.fordscorpio.co.uk/Engine%20Repairs.htm
It isn't.
what they said ^^^
the BOB is the second version of the cossie mod'd 2.8 Taunus/Cologne V6
[Edited on 13/8/2010 by mcerd1]
