Author: Subject: Gear change dilemma - advice needed
wylliezx9r
posted on 3/10/10 at 08:03 PM Reply With Quote
Im building a BEC and want to use steering wheel paddleshift. The problem is the paddles are designed to work with a smaller wheel and will not operate correctly whillst using the big Sierra steering wheel. I have read several threads which indicate that you have to use the standard wheel to pass IVA. If anybody has some advice/ideas how to get around this I would be greatful, obviously after IVA I will be changing the wheel to a smaller sportier item.
Cheers Dan
George Best
adithorp
posted on 3/10/10 at 08:17 PM Reply With Quote
Whats the problem using thSierra wheel? My paddles wouldn't work with one because they hit the edge of the casting for the steering lock to engage on. Not having the steering lock I cut the rim back with angry grinder and it cleared.
You don't have to use the Sierra wheel for IVA. It just makes it easier as it increases the exempt area on the dash for radius' and the padding is garrenteed to pass.
adrian
http://jpsc.org.uk/forum/
mad4x4
posted on 4/10/10 at 06:16 AM Reply With Quote
Was there not a post on here something about if you have no windscreen then the area behind the steering wheel is none exempt.....
Scot's do it better in Kilts.
Richard Quinn
posted on 4/10/10 at 06:33 AM Reply With Quote
I used paddles with a Sierra wheel for SVA. You had to take your hands off the wheel to use them but as it is only for driving it off the trailer and then mainly for Mr Tester to do his speedo test then it's not too much of an issue.
