Author: Subject: Can i modify a plastic radiator ?
steve m
posted on 20/10/10 at 05:44 AM Reply With Quote
I would like to move my rad forward and more upright in the nose cone, but it has a rad cap on the top which would need to be taken off and the resulting hole blanked off,
The rad top and bottom are black plastic
my idea was to remove the cap, and neck, leaving a hole, then make a plastic sleeve that would go inside the hole, glued in place with epoxy/fiberglass then patch the outside as well
Any thoughts ??
regards
mad4x4
posted on 20/10/10 at 06:16 AM Reply With Quote
Maybe plasitic welding compaines can help.
Scot's do it better in Kilts.
dhutch
posted on 20/10/10 at 07:30 AM Reply With Quote
Depends what plastic it is in part, a lot arent that sticky, i dont know whats common in radiators, but say glass reneforced nylon is a bugger to glue to.
As said, a plastic welding company might be able to do a job. But dont forget theres a fair bit of presure in a modern system. You dont want to end up wearing your 105deg C cooling loop contents at 75 on the motorway.
Daniel
mangogrooveworkshop
posted on 20/10/10 at 08:13 AM Reply With Quote
Just get the polo rad SCHIMPLES
posted on 20/10/10 at 11:13 AM Reply With Quote
What's the reason for moving it forward and more upright?
If it's improved cooling/airflow you're after then it might be simpler to make some ducting in the nose to channel the airflow better.
If it's space you're trying to create for something else (oil cooler maybe) then the Polo rad is the way to go. IIRC they can be had for less then £40 from Northern Radiators.
ashg
posted on 20/10/10 at 03:36 PM Reply With Quote
dont do it or your end up like this
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
