Author: Subject: Heater bypass valve
Jed
posted on 7/2/11 at 06:28 PM Reply With Quote
Heater bypass valve
I'm looking for a cable activated heater valve that has a bypass when in the closed position so that coolant still flows. I've had a trawl through fleabay but the valves from modern cars are electronically operated so not suitable unless modifiable.
Does anyone know of a suitable valve?
cheers
Jed
posted on 7/2/11 at 07:24 PM Reply With Quote
Classic range rovers have a vacuum operated one but you can crack the top off the piston and attach a cable easily...
jacko
posted on 7/2/11 at 07:46 PM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=149204
Try this
