JeffJeffers
| posted on 7/2/11 at 06:52 PM |
Fuel pipe.
Just want to make sure I have got this right before I start fitting my fuel pipes.
The pipe from the bottom of my tank is the return. There is 2 pipe attachments on the top of my fuel tank 1 of these is a breather the other is for
the return?
I can use 8mm fuel pipe for the return and the feed?
Thanks Jamie
Davegtst
| posted on 7/2/11 at 07:04 PM |
Why are you using the lowest one for the return? Surely you need to use one of the top ones for the return and the other for the breather. What pump
are you using? 8mm fuel pipe sounds fine.
Ben_Copeland
| posted on 7/2/11 at 07:21 PM |
Think he's just made a mistake, because he says return at the top too.
Fuel feed at the bottom, Return and Breather at the top and 8mm pipe should be ok depending on your engine...
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
| posted on 7/2/11 at 08:15 PM |
You don't need 8mm for return 6mm is more than adequate for the return and is much easier to work.
JeffJeffers
| posted on 7/2/11 at 09:07 PM |
There is an example of why you should read what you write before you post it.
I did mean bottom for feed and not return.
Thanks for the replys. Hopefully get that job finished this week.
