Author: Subject: zetec clutch part no.
lotusmadandy
posted on 14/3/11 at 02:03 PM Reply With Quote
Hi all,
Does anyone have the part nos for the correct clutch plate and cover for a zetec.
The ones we use when fitting to a type 9 box. It is for the 1.8 flywheel.
I had the info saved but have lost it.
austin man
posted on 14/3/11 at 02:12 PM Reply With Quote
Im using the standard 1.8 zetec on with the Capri release bearing, i did run with the standard release bearing but read that the travel of the bearing would be too short after a time resulting in loss of clutch, whilst there would still be plenty of meat on the clutch plate
lotusmadandy
posted on 14/3/11 at 02:16 PM Reply With Quote
Yes i already have this set up in my mk.a friend wants to order the
parts for his build but needs the part no's.
I did keep the no for future reference but have lost them.
austin man
posted on 14/3/11 at 02:29 PM Reply With Quote
ct133 is the bearing number
posted on 14/3/11 at 02:58 PM Reply With Quote
FORD MONDEO MK1 1.6 & 1.8 / MONDEO MK2 1.8 CLUTCH KIT on eBay (end time 01-Apr-11 23:21:02 BST)
Norfolkluegojnr
posted on 14/3/11 at 03:03 PM Reply With Quote
QH part number of mine was QKT690AF. If you bang that into google, loads of suppliers will pop up .
lotusmadandy
posted on 14/3/11 at 03:13 PM Reply With Quote
Thank you gentlemen.
big_wasa
posted on 14/3/11 at 06:06 PM Reply With Quote
Important bit is the THE DIAMETER IS 220MM WITH 1" 23 SPLINE centre.
FORD MONDEO MK1 1.6i 1.8i 94-96 NEW CLUTCH KIT on eBay (end time 12-Apr-11 12:55:13 BST) is £30 posted to your door
lotusmadandy
posted on 15/3/11 at 01:23 PM Reply With Quote
As always this forum is the best.
Thanks for all the replies/advice and for pointing me in
the proper direction
