NS Dev
| posted on 26/7/11 at 08:04 AM |
Water/methanol injection through fuel injectors?
Been doing a little net trawling, which, as seems to be the case these days, has only thrown up lots of americans arguing!
I have found a few examples of people injecting water through fuel injectors, but durability evidence is a little sketchy. One has done a good number
or full load dyno runs, and another used it on a road car for several years.
Anybody got any idea whether injectors are likely to suffer terminal failure in short order?
FASTdan
| posted on 26/7/11 at 08:19 AM |
why would you need to bother when you can buy the proper WI jets for a few quid? Excuse my ignorance....
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
NS Dev
| posted on 26/7/11 at 08:27 AM |
Would like to map the water injection and control it all through one ECU.
I may have missed something when looking but none of the kits I have seen seem to have very good control over the injection, either just switching the
pump (sounds pretty crap) or using a big nasty solenoid which cannot be PWM controlled......
I may have missed something though!
flibble
| posted on 26/7/11 at 08:36 AM |
Just an idea, how about using a nitrous kit/solenoid with one of the progressive controllers. The solenoids/controller I had from Wizards of Nos
seemed very duarable and controllable?
Volvorsport
| posted on 26/7/11 at 09:13 AM |
aquamist map water injection , it surely is possible.
injectors to suit water injection can be found - we use these type of pwm injectors for urea injection in exhausts , theyre made by siemens .
www.dbsmotorsport.co.uk
getting dirty under a bus
NS Dev
| posted on 26/7/11 at 09:41 AM |
ahhhh, interesting! Hadn't thought of adblue injectors......
Yep, I'm aware of the aquamist stuff, will look further into it but on first inspection a lot of it looked like it would be clumsy to drive
accurately with an ecu.....I may well be wrong though as I am a know-nowt when it comes to this stuff!
NS Dev
what vehicles have 12v adblue injectors, just thought most will be 24v!?
NS Dev
| posted on 26/7/11 at 09:45 AM |
just had a look, as I suspected, the aquamist mapped system uses their own controller (all the functions of which I can already do with my existing
DTA S60 Pro ecu) and a stainless steel industrial 12v solenoid valve, plus a shurflo pump
Volvorsport
| posted on 26/7/11 at 10:21 AM |
must say it didnt cross my mind about the 24v.
you could use an inverter , we use a dropper to run a 5v air flow meter . they take very little ampage , in fact we protect them with a 5 amp fuse
but if you can just buy the aquamist valve , that would save you a headache .
Snuggs
| posted on 26/7/11 at 10:36 AM |
Anyone else keep reading the title of this post as WATERMELON
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
NS Dev
| posted on 26/7/11 at 11:10 AM |
think you might be right.....
still tempted to leave a rig in the corner of the workshop seeing how long a fuel injector will work with water for.
just need an injector driver to pulse it...
anybody?
matt_gsxr
| posted on 26/7/11 at 12:03 PM |
You can use an indicator relay. That should pulse it forever. I use it when cleaning them. Don't forget to include an in-line filter.
It will depend on corrosion, some of them go a bit rusty if left in a damp workshop. Both methanol and water are bad for corrosion.
Matt
NS Dev
| posted on 26/7/11 at 02:25 PM |
It's a while since I've been on here, and this has just reminded me why this forum is great!
Cheers, never thought of an indicator relay!
Perfect for a little trial!
Next stop, buy a Shurflo high pressure pump! (these seem to be what all the water injection companies re-badge as their own! )
Volvorsport
| posted on 26/7/11 at 05:04 PM |
i do have a spare adblue injector if you want to try it .
if you think about it carefully , you only ever want just the right amount of atomised water so shouldnt really need to use a pwm device , it just
needs to be a quantity of water over time at pressure , you could certainly alter the voltage to reduce/increase flow of the pump .
i would think if the solenoid valve is small enough it can be controlled with pwm anyway , its either open and shut anyway !
trying to think back when we played with WI a bit , the time between on and off doesnt have to be so finite , i think because of the reason above ,
its just a quantity of water at a certain time , nonthing like the accuracy needed for fuelling .
you could try low pressure squirting !! oo er with a 12v washer pump and a nozzle from a garden squirter , it really can be that simple .
T66
| posted on 26/7/11 at 06:08 PM |
Nat you can borrow my Snow pump if you want, like I said earlier I need a hand with mine...
could stick it in the post tomorrow
http://www.snowperformance.net/products.php?p_cat=324
NS Dev
| posted on 26/7/11 at 06:43 PM |
tempting but I'd better get my own in case I break it!
Looks like they are about £100 new for the shurflo ones
T66
| posted on 26/7/11 at 09:01 PM |
Im happy to let you have a borrow, as we used to get told in the garage "If you bend it you buy it"
whats the chances of it breaking, fairly slim Im guessing - let me know.
You can buy me a shurflo one if you shag it.. You may not be happy with your experiment.
coyoteboy
| posted on 26/7/11 at 10:37 PM |
I recently had a chat with some injector manufacturers as I was looking to use some for precise metering of water in a lab experiement. All the ones I
asked said their internals were stainless/water happy assuming no nasty contaminants. At the moment we have a shurflo pump, fuel pressure reg and
3xID1000 injectors being built into a test rig. PWM from a constant pump pressure is the only reliable way of doing it.
NS Dev
| posted on 27/7/11 at 12:28 PM |
superb!!
thank-you very much indeed, that's the sort of info I wanted to hear!
once again, trust locostbuilders for lateral thinking!!
