Author: Subject: Difference between Cosworth 4x4 & 2wd bottom end
DixieTheKid
posted on 25/10/11 at 10:30 AM Reply With Quote
Greatings chaps,
Can anyone tell me the difference's between a 4x4 & 2wd bottom end?
I know the sumps, water pumps & oil pumps are different but what about the internals! Is it just the pistons & pickup?
Cheers Chris
COS IT'S Worth IT
mcerd1
posted on 25/10/11 at 11:23 AM Reply With Quote
the 4x4's had '200' blocks, they are even heavier and stronger than the 205 blocks
(not to be confused with the old '20' pinto blocks)
I think the pistons are slightly different in that the CR and valve cut outs etc. were done to suit the slightly different 4x4 heads
conrods I'm fairly sure are the same as is the crank
the difference in the oil pump is basicaly just the cap doesn't have the feed for the spray bar (I think the spray jets are on the block instead of the pickup pipe)
thats the basics, I'll add to it if I think of more...
DixieTheKid
posted on 25/10/11 at 01:30 PM Reply With Quote
Yep thats what i thought.
Cheer mcerd
COS IT'S Worth IT
Nick DV
posted on 25/10/11 at 05:01 PM Reply With Quote
Dixie, if you need anything done or any advice re your Cosworth lump, try Rich or Malcolm at Tremona Garage.
Cheers, Nick
"The force will be with you, always!"
DixieTheKid
posted on 25/10/11 at 06:33 PM Reply With Quote
Malc is the rs guru!
COS IT'S Worth IT
Nick DV
posted on 26/10/11 at 11:24 AM Reply With Quote
Too right. Good lads, know their stuff, and rather a clean workdhop to boot!
Cheers, Nick
