Author: Subject: Pinto water pump- rebuildable?
James
posted on 31/8/04 at 02:28 PM Reply With Quote
Have just aquired myself a 1.6 Capri Pinto alloy water pump.
Want to fit it instead of the original Sierra one at it's much lighter and is a quick fit.
Only thing is- it's a lot 'stiffer' to turn than the Sierra one. Best way to describe it is: if I hold the body of the Sierra and spin the pump it will 'run on' for up to a turn. With the new one it stops immeadiately.
The Heynes says there's no fixable parts but I was wondering if anyone's done anything that free them up at all.
James
stephen_gusterson
posted on 31/8/04 at 02:55 PM Reply With Quote
is it that the 'stiff one' has good seals and more friction, and its the 'light' one thats on the way out?
atb
steve
James
posted on 31/8/04 at 03:52 PM Reply With Quote
Typical sort of comment from you Gussetson!
Possible I guess- but the steel Sierra one had only done 60K and the Capri was a 'D' reg so I'd imagine had done more miles.
James
ned
posted on 31/8/04 at 03:54 PM Reply With Quote
finish building the car, worry about 0.5kg lighter water pumps later..
Ned.
beware, I've got yellow skin
James
posted on 31/8/04 at 03:58 PM Reply With Quote
Yeah alright smart-ass... you saw it last night- it's blatantly much easier to fit it now (while it's in bits!) than later when the water will need to be drained and loads of belts/alternator will have to be removed first!
James
EDIT: Anyway, it's your fault for telling me it was all too heavy that I'm paranoid about the weight!
[Edited on 31/8/04 by James]
stephen_gusterson
posted on 31/8/04 at 04:02 PM Reply With Quote
Ned.
nah james - thats much more like what I would say!
atb
steve
posted on 31/8/04 at 04:16 PM Reply With Quote
They're only £12 new, stop being a tight git.
Benzine
posted on 31/8/04 at 04:26 PM Reply With Quote
Oooo where from? I need one ^_^
James
posted on 31/8/04 at 05:13 PM Reply With Quote
Really? Alloy ones?
James
Mark Allanson
posted on 31/8/04 at 05:36 PM Reply With Quote
I bought mine 2 weeks ago, I consider tham as a disposable item like spark plugs etc, it was £9.85 +VAT. They are about this price at ANY motor factors
bob
posted on 31/8/04 at 06:55 PM Reply With Quote
James
I've a spare new ali one sitting in my garage,it also has some resistance when you turn it so no need to worry mate.
If in doubt you can have mine for a tenner and a bacon roll and a cup of tea,i'll even throw in a durite water temp gauge too
ned
posted on 1/9/04 at 09:19 AM Reply With Quote
Bob offer sounds like a bargain! shame i'm not using a pinto
so if you hadn't of snuck out the scrappy with the waterpump in your pocket would they have charged you £15 for it at he scrappy do you recon?
Ned.
