Author: Subject: small manifold nuts
beaver34
posted on 17/2/13 at 10:31 AM Reply With Quote
small manifold nuts
hi,
a need some small manifold nuts, access is really poor and i cannot get the originals on, forgot what they are called though!
and where can i get some?
thanks
mookaloid
posted on 17/2/13 at 10:56 AM Reply With Quote
Sorry but you need some nuts for a manifold? you don't know what they are called, you don't give a size, and you don't say which engine or which manifold or what material........ Or how many
Mmmmmmm tricky
owelly
posted on 17/2/13 at 11:15 AM Reply With Quote
I have some. I've put them in a Jiffy bag and popped them in the postbox.....
http://www.ppcmag.co.uk
mookaloid
posted on 17/2/13 at 11:44 AM Reply With Quote
Are they small ones though?
beaver34
posted on 17/2/13 at 11:45 AM Reply With Quote
Mmmmmmm tricky
i dont want someone to give me some, just they have a special name and ive forgot whats it called.
i know what size i need etc....
just thought someone might know what i was after
mookaloid
posted on 17/2/13 at 11:51 AM Reply With Quote
Ok but you have to give us a bit more to go on... some old engines use brass nuts on the exhaust manifold - is that what you mean?
beaver34
posted on 17/2/13 at 12:00 PM Reply With Quote
sorry been up too early i think for a sunday!
the nuts that ford use are 15mm spanner headed, you cannot get a 15mm spanner in there to tighten them up, i want a nut that has a thinner wall and uses a smaller spanner to allow access. i got some before for the turbo but forgot there name or where i purchased from!
found some any way, like this
http://k-nuts.com/index.php/products/metric-k-nut-ecrou-aviation-metrique/m10x150-hexagonal/
mookaloid
posted on 17/2/13 at 12:04 PM Reply With Quote
They have loads of nuts and bolts etc at Rufforth autojumble http://www.rufforthautojumble.com/
owelly
posted on 17/2/13 at 12:13 PM Reply With Quote
Flange nuts?
owelly
posted on 17/2/13 at 12:19 PM Reply With Quote
or...
http://www.wemoto.com/parts/picture/ho-90304-mm5-000/
posted on 17/2/13 at 02:05 PM Reply With Quote
Loads of nuts use a 15mm hexagon but that doesn't help with the thread size which is the important bit. You need the thread diameter and the pitch to help work out what you want. I've seen 10mm x1.5 ,10mm x 1.25 and also 8mm x 1.25 threads using a 15mm hex nut and probably others as well
beaver34
posted on 17/2/13 at 06:16 PM Reply With Quote
dont think people have understood my reply.
the standard nuts that dont fit due to spanner acess are 15mm.
these k nuts come in the same size m10 x 1.5 but use a smaller 12mm head
beaver34
posted on 23/2/13 at 11:00 AM Reply With Quote
picked some up from merlin motorsport
pic so show difference between stock ford and these k nuts incase anyone needs "small manifold nuts" in the future!
