Author: Subject: Cheap Bike Fuel Pump From HK?
mikeb
posted on 30/7/13 at 11:16 AM Reply With Quote
Has anyone tried one of these cheap fuel pumps from HK?
http://www.ebay.co.uk/itm/New-Gas-Fuel-Pump-Assembly-For-Kawasaki-ZXR-ZX-750-93-03-ZX6R-ZX-600-95-99-/271233032380?pt=UK_Motorcycle_Parts_13&hash= item3f26bfa0bc
jossey
posted on 30/7/13 at 11:41 AM Reply With Quote
Not personally but my rule is....
If it can burn ye house down if it goes wrong
Or set you on fire
Or save your life
Or stop you in your car etc
Then I buy from uk n make sure it is kite marked to British standards
Oh I now have to add to the list.
If it holds water at high pressure (found that out the hard way , £28k damage from Chinese tap flexi hose
David Johnson
mcerd1
posted on 30/7/13 at 11:57 AM Reply With Quote
I'd risk it on somethings, but not a fuel pump...
besides you can get a whole OE pump assembly second hand with the mont and fuel filter for the same money from a bike breaker
posted on 30/7/13 at 12:49 PM Reply With Quote
Which originally came from Japan
mcerd1
posted on 30/7/13 at 01:21 PM Reply With Quote
which is very different from hong kong
I just ment you've got a good chance of an OE quality pump (probably still made in china, but under some kind of quality control) and most good breakers would take it back if it broke in 5mins
mikeb
posted on 30/7/13 at 02:38 PM Reply With Quote
I think you are right it is a gamble, it might be good quality it might be carp. If someone else had bought one and was very happy with it I'd be tempted but I don't want to be the guinea pig!
Breakers it is.
Jenko
posted on 31/7/13 at 08:54 AM Reply With Quote
I just bought some 'copy' aero catches from China.....Fitted one, and it snapped the second time I closed it. now have the OEM part from Aerocatch, and although they look the same, the engineering is far, far better.
MY BLOG - http://westfieldv8.blogspot.co.uk/
