luke2152
| posted on 16/5/15 at 09:42 PM |
charge cooler performance
I've got a charge cooler setup with an ebay barrel style cooler
http://www.ebay.co.uk/itm/Barrel-intercooler-water-to-air-cooler-liquid-to-air-intercooler-4-x-8-/231534575475?
Have a decent pump to keep the water circulating and a quad bike radiator to cool it back down.
Now my expectations were that a charge cooler would be great for keeping inlet temperature down close to ambient and the thing to watch for would be
heatsoak with the water heating up faster then the radiator can cool it down. My experience seems to be the opposite. My air inlet temperature is
getting up over 70c after 10 seconds at full boost (12 psi). The water temperature however is only going from 28c to 31c in the same time so its
definitely not heatsoak.
So opinions please-
Is it because:
*The charge cooler is cheap chinese rubbish
*The charge cooler is too small
*My expectations are too high and I shouldn't worry so much.
mark chandler
| posted on 16/5/15 at 09:52 PM |
The charge cooler is to small.
Think about the Power required to compress the volume to 12psi, if supercharged maybe 30hp which is a around 24kw of heat you are which you are trying
to lose.
You need to worry at 70 degrees heat and get it below 40, if you empty of water what is the inlet charge heat as this will tell you if it's
basically cheap rubbish.
Air to air are far more efficient BTW
Dick
| posted on 17/5/15 at 07:01 AM |
Sounds like cheap ebay rubbish to me . I have a pwr on my 440 cosworth and it runs anout 10 deg above ambiant. On full boost
luke2152
| posted on 17/5/15 at 07:24 AM |
Its a little smaller than your one Dick (4x8). I guess I don't mind forking out for a pwr one if it will definitely fix the problem. The
equivilent pwr one by the way is rated to 350hp so should be more then enough on paper at least.
Dick
| posted on 17/5/15 at 07:59 AM |
Are you running the radiator at the very front of the car and do you have a fan on it.
Also check the direction of water flow in the cooler and the radiator it is an easy mistake to make
luke2152
| posted on 17/5/15 at 08:08 AM |
Water flows from the bottom of the rad to the pump to the cooler (in the throttle body end out the turbo end) and back to the top of the rad. Theres
no fan on the rad but the water stays cool.
If anything I would have guessed an airlock in the cooler but the in/outlets are at the very top so I can't see how it could trap air.
Dick
| posted on 17/5/15 at 08:18 AM |
Is the cooler above the header point they do take a lot of filling to get the air out pump running the correct way ? Can you feel the water being
pumped running? Have seen even the small ones work well
luke2152
| posted on 17/5/15 at 08:29 AM |
Cooler is well below the rad header. I have clear hose on the outlet and can see a lot of flow with no bubbles.
Dick
| posted on 17/5/15 at 08:35 AM |
Give us a call and pop it up I'll have a look at it seems bit odd it's not working . I have seen these coolers on a Saab turbo working
well , may be something simple
luke2152
| posted on 17/5/15 at 08:36 AM |
Can do - when is a good time for you. You're certainly nice and close
Dick
| posted on 17/5/15 at 09:03 AM |
Any day but Thursday but call first to make sure I'm about and not out having fun
luke2152
| posted on 17/5/15 at 09:14 AM |
OK will most likely be mid afternoon one day - thanks
Dick
| posted on 21/6/15 at 06:52 PM |
u2u sent
