Author: Subject: Crank case vent valves.
Rorty
posted on 3/10/05 at 11:30 PM Reply With Quote
Anyone care to comment on these Krank Vents?
Cheers, Rorty.
gazza285
posted on 3/10/05 at 11:47 PM Reply With Quote
I understand the theory that they are working with, after all many a dry sump system can run a partial vacuum in the crank case, but these use an active pump to achieve this. In a situation with zero ring leakage it sounds like an ideal setup. As this is impossible I would tend to think of such things as bullshit baffles brains engineering.
Rorty
posted on 4/10/05 at 12:53 AM Reply With Quote
I'm not an engine expert and was just curious, but I was thinking along the same lines.
Although, I've seen big V8 drag engines with a flapper valve on each header bank which are supposed to suck the crank cases clear at high revs. They usually know their onions, but maybe it's a different scenario.
Cheers, Rorty.
gazza285
posted on 4/10/05 at 01:14 AM Reply With Quote
Sounds like they are utilising the good old venturi effect to create a depression in the crankcase. I don't suppose they worry much about a little oil in the exhaust gas. I presume that as well as rebuilding the engine between runs the oil level is checked as well.
G.Man
posted on 4/10/05 at 05:31 AM Reply With Quote
Looks like a stock crankcase breather from a car adapted for a bike...
ie recycles the crank fumes into the intake...
The turbo version works identically to that on my cossie motor...
Opinions are like backsides..
jimgiblett
posted on 4/10/05 at 08:44 AM Reply With Quote
I had one of these on my old engine. Never did a before / after dyno test but if there was a gain it was minimal. The main advantage it gave was reduced oil breathing / consumption.
I've got one in the garage if anyone wants to make me an offer ?
