ChrisGamlin
| posted on 10/10/05 at 08:59 PM |
Exhaust Lambda blanking bolt
Anyone know where I can get an exhaust lambda blanking bolt from? I lost mine at Rockingham so need to sort a new one out before venturing back out
again.
Chris
[Edited on 10/10/05 by ChrisGamlin]
Ben_Copeland
| posted on 10/10/05 at 09:07 PM |
Can you not weld any old bolt in ?
Or would you like it removable? or is it stainless?
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
tks
| posted on 10/10/05 at 09:14 PM |
an labda device is an performace wise an good thing....
i would stick it on always...
with labda at 0,9 you have maximum performance! and MCU of an car tunes for labda = 1
but for racing performance we will need 0,8/0,9 but if you take away your labda
sensor doesn't your mcu go in safe mode?
or am i untherstanding that's an auxilary test/tune hole in your escape??
Tks
Ben_Copeland
| posted on 10/10/05 at 09:20 PM |
I took it as he never had one, just the hole
Ben
Roadster
Surrey Dave
| posted on 10/10/05 at 10:17 PM |
I think it was here that I got Lamda sensor sized nuts to weld onto my manifold, so they may have the bolts, ............does a spark plug fit in an
emergency?
BDM Fastenings
Unit 10, Royce Rd, Crawley, West Sussex RH10 9NX
Tel: 01293 548186
Wadders
| posted on 10/10/05 at 10:33 PM |
Yes i think the thread is m18, same as some spark plugs.
emergency?
BDM Fastenings
Tel: 01293 548186
Ketchup
| posted on 10/10/05 at 11:41 PM |
I think i have a couple at work, will check tomorrow and let u know and stick one in the post or something
stevebubs
| posted on 10/10/05 at 11:54 PM |
Chris,
Try sticking a spark plug from a car in the boss. If you want flames, just hook it up to a 12v supply and switch!!
Failing that, I've probably got a spare lambda sensor you can stick in for a while if you want.
Stephen
PS can you ask Rhodri if he's lost a pair of waterproof trousers? If he has, they're still rolling around in the boot of the tintop.
[Edited on 10/10/05 by stevebubs]
NS Dev
| posted on 11/10/05 at 08:24 AM |
yep, pinto plugs are the right thread
Rorty
| posted on 12/10/05 at 04:06 AM |
If you decide on a bolt to blank the boss, you'll need a M18 x 1.5 bolt and not a standard ISO M18 bolt.
Cheers, Rorty.
ChrisGamlin
| posted on 12/10/05 at 07:44 AM |
Cheers all, yep its the blanking bolt I need (manifold has the boss welded in). A spark plug is the backup plan but it kinda looks rather daft hanging
out a beautifully tig welded manifold!
Cheers ketchup, would be most appreciated and will forward relevent beer tokens
Steve, will ask him, knowing Rhodri the answer will probably be yes!
Chris
Ketchup
| posted on 12/10/05 at 12:01 PM |
Hi, i have a found a blanking plug, do you want to u2u me your address and i will post it to you.
ChrisGamlin
| posted on 12/10/05 at 05:42 PM |
U2U sent, many thanks
