GazzaP
| posted on 9/2/06 at 01:51 PM |
Type 9 gear box oil seals
Hi all!!
I have a oil leak from in between my gearbox and engine the engine is brand new and for all i can see and taste it is gear oil, will this be the main
seal around the shaft that is leaking and what kind of job is it to replace i presume it is fairly easy once the box is out, i would rather remove
the gear box than engine to be honest. Any ideas or suggestions will be gratefully recieved,
Many thanks Gary
www.gmpmotorsport.co.uk
Johnmor
| posted on 9/2/06 at 06:40 PM |
Simple to replace , remove the gearbox ,and remove the four 10mm bolts holding cover plate and bearing support shaft. Pay attention to the position it
came off as it has an oil passage at its base.
Remove the seal and replace, you will need a new gasket, it could be the gasket that is faulty.
15 mins, job done. (apart from gearbox removal)
dave r
| posted on 9/2/06 at 09:26 PM |
my leak was a gasket problem
its got to be a thick one as the front bearing is located with a circlip
my gasket wasnt thick enuff
