Author: Subject: oil catch tank
westf27
posted on 13/2/06 at 04:51 PM Reply With Quote
oil catch tank
Thought i'd have a go at making a catch tank.Curious as to what is inside.the inlet and outlet must differ so as the oil can drip into the tank?.Anyone have a sketch or cut one up?
RazMan
posted on 13/2/06 at 05:28 PM Reply With Quote
Just make sure that the inlet points away from the outlet breather to prevent oil passing straight through, bung a filter on the top and possibly a sight glass to let you know when it needs emptying.
[Edited on 13-2-06 by RazMan]
Raz
westf27
posted on 13/2/06 at 05:30 PM Reply With Quote
catch tank
so just a posh expensive can!
Did you pass sva with your sparco wheel?
locost7-online.com
posted on 13/2/06 at 06:15 PM Reply With Quote
use a fairly big breather pipe from the engine, mine is 11/2", it will reduce the amount of oil being blown out!
Locost Xflow 150bhp injected! Sold :-(
Facebook blog https://www.facebook.com/Johns-Tiger-Avon-Build-814223212056368/
PLEASE NOTE THIS MEMBER IS NOT A TRADER.
posted on 13/2/06 at 06:46 PM Reply With Quote
i need to add a catch tank, ideally this week, but the fitting on the engine is just a large hole. I guess i'll have to measure it and cram something in! The current filter alone cant cope.
mookaloid
posted on 13/2/06 at 07:14 PM Reply With Quote
Mine is plumbed back into the sump at the bottom where you would normally have a drain tap.
So no need for a sight glass or messy oil draining just make sure the filter is clean evey now and again
tom_loughlin
posted on 13/2/06 at 09:28 PM Reply With Quote
im just using a mini aluminium can (schweppes tonic water i think)
cheap and cheerful
