Author: Subject: Diametre of cam pulleys
ettore bugatti
posted on 20/2/06 at 04:53 PM Reply With Quote
Does anyone happen to know the size of the camshaft pulleys of the Ford Zetec or Toyota 4AGE?
It is for twincam Mini...
Thanks in advance
Dusty
posted on 20/2/06 at 05:04 PM Reply With Quote
120mm dia x 30mm thick. Hole for cam is 11mm but slight taper. 40 'teeth'
ettore bugatti
posted on 20/2/06 at 05:06 PM Reply With Quote
Thanks! This data is for the Zetec?
Dusty
posted on 21/2/06 at 02:35 AM Reply With Quote
Sorry I should have said zetec.
ettore bugatti
posted on 1/3/06 at 09:29 PM Reply With Quote
Hmmm, that's sadly too large. I need something with a diametre of 90mm or smaller.
Any suggestions?
Richard
eddymcclements
posted on 1/3/06 at 11:00 PM Reply With Quote
Unlikely to be a cam pulley, then. If you used a 90mm cam pulley the crankshaft pulley would be 45mm, right? That's smaller than most cranks. Best bet for a toothed belt pulley is an industrial bearing and drive supplier. They're available in all diameters and tooth shapes. Search for "synchronous drive" or HTD belts.
Eddy
[Edited on 1/3/06 by eddymcclements]
ettore bugatti
posted on 5/3/06 at 11:35 PM Reply With Quote
@eddymcclements:
Well, I know that Ford Pinto cog wheels fit and there are other engine cam pulleys that fit. So it's not impossible.
But what's the dimension of your 4AGE cam pulleys?
I will anyway research your tip on HTD belts.
Richard
