COREdevelopments
| posted on 18/3/06 at 09:59 AM |
relay pack
im using a luego loom to wire up my car. now it never came with a relay pack. i find it strange why they would sell these seperatly as i thought you
would need them both?
is there any other way of wiring up my siera stalks or do i have to buy a luego relay pack? if so what do you get for 55quid?
any advice thanks
Rob
Shandylegs
| posted on 18/3/06 at 10:49 AM |
You get 2 or 3 relays (Can't remember exactly) plugs & wire. If you hadn't already got the loom I would have told you to steer clear,
loom comes completedly unwrapped & is supplied with no connectors at all.
I was exceptionally dissappointed, IMHO not good value at all.
Are realys needed? I would always use relays whever possible as I don't like the idea of all that current passing through the column switches,
but in reality it depends on the column stalks you have. Early sierras had much thicker wiring for the column switches whereas in the later cars the
column switches were protected via relays and therefore used much tinner gauge wiring.
Ta
Duncan
COREdevelopments
| posted on 18/3/06 at 10:55 AM |
ye i was not truely happy with it myself, especially the manual and lack of a true wiring diagram. which loom would you recommend as ithought they all
came with no connectors.
dave1888
| posted on 18/3/06 at 11:55 AM |
Try here
http://www.premierwiring.co.uk
Dusty
| posted on 18/3/06 at 01:03 PM |
Individual bulkhead 30A relays are £6 at halfrauds. 5 x 6 = 30 plus a little extra work and you got one for the fan, dip,main,horn and fuel pump.
liam.mccaffrey
| posted on 18/3/06 at 01:06 PM |
coredevelopements, where abouts are you? im down in milford haven in the west
Build Blog
Build Photo Album
COREdevelopments
| posted on 20/3/06 at 07:33 PM |
hey liam im in cross hands near carmarthen. so not that far away
