BKLOCO
| posted on 8/4/06 at 02:54 PM |
Strange noises.
Now that I have got my engine running to an acceptable standard I have a bit of a problem.
When the engine is idling at about 800-900 rpm there is a fairly loud rumbling/ clanking noise. If I increase the revs to about 1000-1100 it goes. It
also goes when I dip the clutch.
I'm thinking gearbox input shaft bearing.
What are peoples thoughts?
It's a standard type 9 box.
What type of bearing is supporting the input shaft? radial ball? single row/double row? pre-loaded?
Anyone got an assembly drawing of type 9?
Thanks in advance for any input (no pun intended )
Brian.
theconrodkid
| posted on 8/4/06 at 03:04 PM |
got oil in t box? remember you have no sound deadening around the engine/box,you will hear all manner of strange noises
who cares who wins
pass the pork pies
Fozzie
Maybe too much free play in the cable? If there is more than about 1/8", it may well be that, try first?
HTH Fozzie
| posted on 8/4/06 at 03:13 PM |
You have got a spigot bearing fitted in the end of the crank ?
BKLOCO
Thanks Fozzie, that was my first thought (and RazMans who lives just round the corner) so I spent all morning fiddling (in the nicest possible way)
Still the same
BKLOCO
| posted on 8/4/06 at 03:15 PM |
Yes.
| posted on 8/4/06 at 03:16 PM |
[Edited on 8/4/06 by britishtrident]
BKLOCO
| posted on 8/4/06 at 03:18 PM |
I have definately got oil in the box.
I realise that things are going to be louder but this just sounds wrong if you know what I mean.
Fozzie
| posted on 8/4/06 at 03:28 PM |
Dry spigot? or.....1st motion shaft?
BKLOCO
| posted on 8/4/06 at 04:13 PM |
This is beginning to look like a slight set-back
I have this bad feeling.
Not sure whether to strip it out and investigate or run it till it does something nasty
The engineer in me is winning at the moment and I think I'm going to have to investigate.
Danozeman
| posted on 8/4/06 at 04:17 PM |
Have u driven it yet?
May just be that the oil hasnt got round the box yet to take up any play?
Dan
muzchap
| posted on 8/4/06 at 06:09 PM |
Hmm I had a similar noise in an old sierra - years ago - as soon as clutch dipped it went.
Turned out it was clutch release bearing or something like that.
I'd actually do what Danozeman says - take it for a thrash and see if it settles in :p
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
NS Dev
| posted on 8/4/06 at 06:13 PM |
funnily enough I had the same in my old XR4x4, and that was the clutch release bearing carrier rattling on the trumpet housiing on the front of the
box. The lightest pressure on the clutch pedal stopped it.
trogdor
| posted on 8/4/06 at 06:30 PM |
that sounds like the clutch release bearing or something in that area. my car is currently making that sort of noise.
ie it goes when u increase revs or dip the clutch. my dad is certian that it is this and i will be investigating when i take the v4 out to trial fit
the zetec i am trying to shoehorn in.
i would drive it for a bit first to see if it does improve as it shouldn't cause any damage. however it will need sorting fairly soon.
hope it isn't anything more than the release bearing. good luck
flak monkey
| posted on 8/4/06 at 06:46 PM |
All the fords I have ever driven (about 4 in total) have had noisy clutch release bearings and most of them havent been more than 7 years old. Its
most likely to be that. If it is then really light pressure on the clutch pedal will stop it.
Sera
http://www.motosera.com
zetec
| posted on 8/4/06 at 09:47 PM |
Mine does a similar thing if I let the revs drop too low, with 800-9000rpm its fine. Drive it and let it warm up and see what happens. Whats the worse
that happen?
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
omega 24 v6
| posted on 8/4/06 at 11:15 PM |
I've got a type 9 rebuild pdf somewhere (I think) U2U me if you want it.
