Author: Subject: Blue gasket sealant - does it really need 24 hours to dry?
Just
posted on 4/6/06 at 02:40 PM Reply With Quote
Does blue sealant really need the 24hrs it says on the back before you can refill with oil/water?
DIY Si
posted on 4/6/06 at 04:48 PM Reply With Quote
Depends upon what sort of blue sealant it is. Is it hylomar blue, or some other make?
Just
posted on 4/6/06 at 04:57 PM Reply With Quote
Good point, it is Loctite 595 - Blue Silicone RTV Compound.
DIY Si
posted on 4/6/06 at 04:59 PM Reply With Quote
Don't know about that, never used it. I presume it says to leave it for 24 hrs on the tube?
Just
posted on 4/6/06 at 05:00 PM Reply With Quote
Yep, I guess I will just have to be patient - if it means a good seal I am happy.
DIY Si
posted on 4/6/06 at 05:04 PM Reply With Quote
Loctite tend to know how to stick stuff together so I'd go with whatever they say. Bit of a git if you're waiting on it, but at least it'll be sealed.
posted on 4/6/06 at 05:14 PM Reply With Quote
Water pump gaskets shouldn't need silicon to make them seal ! Hylomar if anything then you don't need to wait . Most silicons start to go off when exposed to atmosphere
