jos
| posted on 5/6/06 at 08:30 AM |
Exhaust welding
One of the welds has cracked on my exhaust where the 421 system goes from 2 into 1 just before where the 1 section clamps into the exhaust can.
Do i need to find somebody with special welding equipment to reweld it or can I take it to my local garage to fix.
Also does it matter if its stainless. Does stainless need special tools????
nitram38
| posted on 5/6/06 at 08:43 AM |
Stainless requires the correct stainless wire if Mig welded or the correct Tig rods.
If you can use a mig, then all you need is to change the wire. If you need it Tig welded, take it to someone who does this regularly. Tig welding
takes a bit of time and a steady hand.
Tig is a neater way to do things, but the mig will lay down thicker welds. If you are unsure, post a photo so that we can tell you what kind of welds
you already have.
andyharding
| posted on 5/6/06 at 08:45 AM |
Can you make it here Jos? If so I'll pick up a roll of stainless MIG wire and have a go for you.
andyharding
| posted on 5/6/06 at 08:46 AM |
P.S. you can weld stainless with mild wire and this is what a local Shit-Fit would probably do but the weld would then rust.
nitram38
| posted on 5/6/06 at 08:50 AM |
Using steel wire will work, but it also would be a weaker weld aswell as the rusting.
For a longer life weld, I recommend using the correct wire.
jos
| posted on 5/6/06 at 08:57 AM |
yeah probably andy. Thanks for the offer. Dont get the wire just yet, because I'll ask a couple of local garages first, but I may very well
take you up on that offer
