Author: Subject: Backfire through bike carbs
IainB
Builder
Posts 236
Registered 17/11/05
Location Glasgow
Member Is Offline
Photo Archive Go!
Building: Fiat X1/9 - GRP widebody, Bike carbs, Megajolt
posted on 11/6/06 at 06:23 PM Reply With Quote
Finally got the engine started today! WOO!!!!
Runs well apart from slight backfiring through the carbs What exactly causes this? is the ignition too retarded? Idle mixture too lean?
It only happens when you jab the throttle rather than taking the revs up slowly... does this mean its the spark timing?
Iain
http://s43.photobucket.com/albums/e365/IainB1986/
yorkshire-engines
posted on 11/6/06 at 07:08 PM Reply With Quote
usually caused by an air leak or no air filter put the choke on a little if it goes away too lean due to above
Danozeman
posted on 11/6/06 at 10:29 PM Reply With Quote
This is interesting i have the same problem.
Dan
IainB
Builder
Posts 236
Registered 17/11/05
Location Glasgow
Member Is Offline
Photo Archive Go!
posted on 11/6/06 at 10:36 PM Reply With Quote
Mine seem to be sorted. Checked silicone hose for leakage and turned idle screw 1/2 turn out and its running fine now.
It was only one cylinder that was doing it so it was either a small leak or the idle screw isnt quite ballanced with the others
Iain
tks
posted on 12/6/06 at 09:09 AM Reply With Quote
mhhh
when promptyly accelerating,
the spark need to come different (dunno it was earlier or retared)
also more fuel is needed during that small moment...
Sow think it has to do with the spark timeing.
when growing in revs bit by bit you don´t have de squirt and the spark problem.
Tks
TangoMan
posted on 12/6/06 at 08:23 PM Reply With Quote
Fuel
If blipping the throttle produces backfires, it must be fuel. You require less advance with the throttle opne than progressive acceleration as cylinder filling will be better.
I would suggest that it will be a weak mixture. If only one cylinder I would check that all slides are lifting at the same time and by the same amount.
As was said previosuly, see what happens with a small amount of choke.
