Ace Sportscars
| posted on 14/6/06 at 11:37 AM |
Cambelt probs!
My Pinto cambelt ripped some teeth off a few weeks ago causing my car to come to a halt. The engine was rebored to a 2.1 and as far as I know
wasn't skimmed.
Does anyone know if the pistons hit the valves in these occurances or am I safe. I haven't taken the head off to take a look and was hoping a
quick change of cambelt would be enough to get me up and running again. Say your prayers for me!
mangogrooveworkshop
| posted on 14/6/06 at 11:39 AM |
There is a post that was done very recently about this very subject try search
andy d (rizla)
Senior Builder
Posts 357
Registered 9-1-05
Location aveley in essex
Member Is Offline
Photo Archive Go!
Building: on road MNR VORTX FIREBLADE chassis # 1
posted on 23-4-05 at 12:45 Edit Post Reply With Quote Report Post to Administrator
i thought the 1600 hits but the 2000 misses due to having a taller head?
snoopy
Posting Freak
Posts 1114
Registered 20-1-04
Location here
Member Is Offline
Photo Archive Go!
Building: A NEW LIFE
posted on 23-4-05 at 12:57 Edit Post Reply With Quote Report Post to Administrator
yep got to agree 1600 hits 2L misses
[Edited on 14-6-06 by mangogrooveworkshop]
ReMan
| posted on 14/6/06 at 11:54 AM |
That'l be this one then...
http://www.locostbuilders.co.uk/viewthread.php?tid=46594
andyharding
| posted on 14/6/06 at 12:04 PM |
The only way to be sure is to strip the head down. You know it's the right way to do it any you're just being lazy if you don't...
mookaloid
| posted on 14/6/06 at 12:09 PM |
I would just fit the belt and try it. If it's no good you'll soon know and you probably won't damage it more than it is already
Mark
Ace Sportscars
| posted on 14/6/06 at 01:05 PM |
Thanks guys, I'll get a new belt fitted and keep my fingers crossed...mind you they're crossed already for tomorrows game...C'mon
the England!
| posted on 14/6/06 at 02:04 PM |
Mark
probably stating the obvious but you would slowly turn the engine over by hand with plugs removed and stop should there be any resistance; maybe done
best with rocker cover off as well?
maybe worth draining the oil and examining for metal and broken piston bits
[Edited on 14/6/06 by 02GF74]
Just
| posted on 14/6/06 at 02:39 PM |
You will need to set the timing again too, and I suppose you could take all the plugs out and test for compression if you have a tool. This would
tell you if the timing is back in and if there has been damage - wouldn't it?
| posted on 14/6/06 at 04:16 PM |
Just turn the cam pulley, I know the standard 2.0 doesn't make contact (mine anyway) but if you have a hot cam or skimmed head it may. You
can't do a compression test till it's back together but you can set each piston to tdc while you check if they hit.
andyharding
| posted on 14/6/06 at 05:02 PM |
I'd be more worries about why it ripped the teeth off the belt to begin with...
