Author: Subject: Pinto Cluch Cable Indy - Help!
Howlor
posted on 21/7/06 at 05:02 PM Reply With Quote
My mate has just passed SVA first time at Beverley with his MK Indy Pinto. Just after the test was complete the clutch cable popped off the arm. After a number of failed attempts to get it back on we towed her home, luckily on 2 miles away. Every now and again you think you have it hooked over but the a couple of clutch actuations and it's off again. He is running the alloy RS2000 bell housing and type 9 box. How the hell do you get the nipple into the clutch arm? The access hole is only an inch from the bulkhead.
Thanks,
hector
posted on 21/7/06 at 05:42 PM Reply With Quote
how about a return spring attasched to the clutch arm so that it keeps tension on the cable at all times!!
cheers colin
posted on 21/7/06 at 05:52 PM Reply With Quote
Or perhaps a positive stop to stop the pedal overreturning?
Howlor
posted on 21/7/06 at 06:18 PM Reply With Quote
I need to get the thing on in the first place before remedying the problem! I can't see the release arm or feel it to get the nipple in position.
