Author: Subject: Improved Megajolt map for Pinto
TangoMan
posted on 1/9/06 at 09:05 PM Reply With Quote
I spent much of last weekend driving with the laptop connected playing with ignition settings.
I have given more advance and moved it down the rev range which seems to have found a lot more midrange and better economy.
I still feel that there is more to go but it is noticably better now. 90mph was less than 1/4 throttle!!
Summer's here!!!!
scoop
posted on 2/9/06 at 07:06 AM Reply With Quote
Do you use an air/fuel ratio device when doing yours?
TangoMan
posted on 2/9/06 at 09:03 AM Reply With Quote
No. I know the mixture is good at most throttle openings but is very rich just above tickover. I am looking at new pilot jets to fix this.
I am just altering timings them driving various types of road including low revs up hills to test for pinking. I feel I still need more timing at medium throttle openings but this needs to be done progressively as each adjustment potentially brings higher revs for lower throttle openings.
I also feel I can bring in the total advance earlier but I will probably only find out once I get on a rolling road.
I have copied the map into my photo archive.
Summer's here!!!!
roadrunner
posted on 2/9/06 at 12:59 PM Reply With Quote
are you running bike carbs or webbers.
Sorry just checked your photos.
What bhp do you think you have , and also i noticed the weather gear , did tou make it yourself and could you post some pics of it up, please.
[Edited on 2/9/06 by roadrunner]
