cct7kitcars
| posted on 8/9/06 at 01:56 PM |
any one got a 205 block pinto engine
beer tokens waiting will pick up
joe
cct7kitcars
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in
sideways, Chardonnay in one hand, Tequila in the other, body bearing battle scars and totally worn out, screaming- WOO HOO!! What a Ride!
graememk
| posted on 8/9/06 at 02:19 PM |
how did the sva's go then ?
cct7kitcars
| posted on 8/9/06 at 02:25 PM |
i think they change the rule book every time i go only took one car hence need of an engine bloody thing started to burn oil the other car failed on
the mushroom inserts be warned they need a second bolt to make sure they cant come out new to me this one all the other cars passed without and the
speedo was reading out so phone call to speedycables who calabrated it
joe
DarrenW
| posted on 8/9/06 at 02:35 PM |
Sorry - no spare pinto.
But mushroom adaptors!!!!! Where di dthat idea come from. How do you fit a second bolt?
Seeing as OEM shockers are nipped in place by the upright i hardly see how they can fail a 7 for using the same fixing method.
Do they want you to fit second pinch bolt or drill and tap into the main body and fit something like a large grub screw as a secondary fixing?
Sounds mad to me.
cct7kitcars
| posted on 8/9/06 at 02:43 PM |
Sounds mad to me.
cct7kitcars
| posted on 8/9/06 at 02:44 PM |
thats what they want me to do i was really pissed off
joe
DarrenW
| posted on 8/9/06 at 03:05 PM |
Hijack!!! Mushroom discussion
Surely that will weaken the upright. The pinch bolt acts by pulling material around the main body of the upright. Drilling through it then adding a
bolt (which will not only tighten down onto the mushroom but also add an equal but opposite force) would surely weaken its structure.
I may be wrong and stand to be corrected. M6 wont weaken as much as M12 etc.
I dont see how the mushroom adaptor is doing anything different to a standard Sierra shocker.
Sounds like you have grounds for a serious discussion on this one with a more senior VOSA bod.
i looked for a block on ebay to apologise for the hijack. Nothing stood out on quick inspection.
cct7kitcars
| posted on 8/9/06 at 03:18 PM |
i spoke to dean at luego about this mushroom and he drills a hole and taps it and uses a grub screw any
joe
James
| posted on 8/9/06 at 05:39 PM |
That is just blinkin daft.
The balljoint only has a single nut holding it on too.... are they going to ban them aswell?
James
- Muhammad Ali
donut
| posted on 8/9/06 at 05:43 PM |
Is there not another SVA station you can take your cars too? Thats just stupid. Tell them to clarify this in writing from head office..... or write ti
the head office to complain...i would! If you do that for the mushroom then that means all other bolts need doing. Stoopid!!
Guinness
| posted on 8/9/06 at 06:34 PM |
hang on a minute, isn't this at beverley, the sva station that must have passed loads of mk's and mac1's which have this exact
arrangement?
WTF is going on!
Mike
wilkingj
| posted on 8/9/06 at 07:17 PM |
Hmm.. I can see the SVA mans point.
Doesnt the Ford Shock / leg have a thin plate that sits in the gap and the bolt passes through it, thus securing it in place.
SVA man passed my mushrooms just clamped in.
As for the Ball joints they must have either nyloc's or a castellated nut and split pin. ie not just a nut on its own. Spring washers are not
acceptable either.
Best Regards
Geoff
http://www.v8viento.co.uk
