Author: Subject: Weber Jets for a Zetec
JackNco
posted on 12/9/06 at 10:28 PM Reply With Quote
Heya all, me again!
Ive been calling round a few companies today about the Weber DCOE 40/45 carbs. Does anyone know if its posible to buy replacment jets to convery standard DCOEs to the zetec Jets Tiger ship them with. tiger refuse to sell them seperatly and ive had no luck diging up information on anyone else that will sell them seperatly so i can get some carbs off ebay and get them working properly.
Thanx in advance
John
DIY Si
posted on 12/9/06 at 11:20 PM Reply With Quote
Your best bet is a rolling road which is used to this engine/carbs. They should be able to set everything up and fit the correct jets.
Sun Tzu, The Art of War
Surrey Dave
posted on 13/9/06 at 07:44 AM Reply With Quote
There are a few places that you can buy Weber jets from , I guess Tiger don't want to let you know their jet settings , someone one here may be able to give you a base setup but the carbs would then need checking /fine tuning on a rolling road.
Many people fit bike carbs , particularly R1 Yamaha from Bogg Bros up t'north they can supply them with a good base setting as they have done a lot of these carbs for Zetec.
They may even guess at some Webers jetting for you.
givemethebighammer
posted on 13/9/06 at 08:58 AM Reply With Quote
I posted a set of jet settings and an ignition map as used by Raceline
http://www.locostbuilders.co.uk/viewthread.php?tid=43743
ps the Blackbird bike carbs, I now have are loads better than the webers.
[Edited on 13/9/06 by givemethebighammer]
Schrodinger
posted on 13/9/06 at 09:47 AM Reply With Quote
Have you tried Webcon?
NS Dev
posted on 13/9/06 at 10:57 AM Reply With Quote
you need to put it on a rolling road if you are at all serious.
roughly quoting a well known engine builder, "giving out jet sizes is like telling somebody how far they need to press the accelerator to do 100mph"
there are so many variables you need a rolling road
Stu16v
posted on 13/9/06 at 08:35 PM Reply With Quote
I like that - so very true...
garage19
posted on 14/9/06 at 12:26 PM Reply With Quote
Go to a model makers shop, buy some drill bits and re drill the jets you have....
If you need a smaller jet just solder them up and re drill!
roadboy
posted on 14/9/06 at 07:17 PM Reply With Quote
It is not just jet sizes that influence the running , you have air idle jets, emulsion tubes, air correction jets, main jets etc, & choke sizes to consider. To get all of this right on a rolling road with a good operator is costly. It is probably better to go for throttle bodies & fully mapped ignition & fuelling with an aftermarket ecu, which will produce better power, torque, fuel consumption & emmissions.
Regds
Ian
Jude Performance Services
