Furious D
| posted on 20/9/06 at 07:47 PM |
Stiff Gears
Hi all,
Just had a test drive in a Tiger Cat E1 2.0 Pinto running twin 45's and overall it was great, feet got toastie.....
One question though....
The gearbox was very stiff, especially going from 4th to 5th. It was also difficult to find 1st on a number of occasions. The guy who currently owns
it said it will take some getting used to and it was partly due to the Gear Remote.
How stiff should they be?
Am i worrying about nothing?
What could be the problem?
Solution?
D
| posted on 20/9/06 at 08:06 PM |
Solution?..... rip it out and stick a bike engine in it....sorted.
Phil
gazza285
| posted on 20/9/06 at 08:22 PM |
Phil
These posts used to be amusing, but I fail to see how it answers the question in any way.
pjavon
| posted on 20/9/06 at 08:28 PM |
then they wont be stiff, they'll be notchy
Always keep a big hammer and a condom in your toolbox, if you can't fix it with the hammer
| posted on 20/9/06 at 08:42 PM |
Phil
I didn't post it for your amusement and it is a viable solution to the problem, (although maybe it could have been worded better). It is also a
lot more helpful than your response, which by the way, doesn't even address the question.
Phil
| posted on 20/9/06 at 09:01 PM |
Got a home made remote on my type nine with quick shift. Don't have any problems with stiff gears at all , in fact I may shorten the lever a bit
more . Not sure what type of remote Tiger use but suspect it may be the type that fits above the gearbox ?rather than in line with the gearbox
selector rod
| posted on 20/9/06 at 09:13 PM |
Some remotes (including mine) have the gearstick a bit too short, making moving it around a bit hard - mine's the same principle as Rusty
Nut's, but I'm thinking of going longer!
You have to remember that the original gearstick was a yard long and was like stirring soup - easy to move, but took up some operating space.
I'm thinking of making my stick a bit longer (ooer!) which should make it a lot easier to shift gears.
Also, remember that the more slop you have in the mechanism the worse it will be - mine's very direct, but a lot aren't.
matt.c
| posted on 20/9/06 at 09:25 PM |
Sorry but found that very funny
Schrodinger
| posted on 20/9/06 at 09:36 PM |
If it's the standard Tiger remote then some find they can be quite difficult to set up
phoenix70
| posted on 21/9/06 at 10:48 AM |
My car is exactly the same, it can be quite difficult to get 5th from 4th, but I don't think it's a problem that you need to worry about
at all. The bigger problem I have anyway is finding reverse instead of 1st.
Scott
oliwb
| posted on 21/9/06 at 03:16 PM |
As mentioned it depends which type of remote its using. My CAT uses the newer westfield type one. The old ones are generally crap and not worth
messing with since you can buy better remotes direct from Tiger now! If it is the newer one there are still a few things to do to make it work
properly. Firstly if bought from tiger you need to get a different bit made up on a lathe. The westfield one allows you to clip in a plastic bit.
However, the tiger one is to wide for the bit to clip on but to small to leave without doing anything or its just sloppy! Also you need to check to
see if anyones messed with the fulcrum point. If they have theys hould have put some washers under the mounts to rasie the whole lever up if they
haven't it will be harder to move....failing all that slather it in copper or CV grease and screw it down well....SVA man said mine was the
smoothest Tiger one he'd used in ages - not being cockey or anything! If you need any help with it u2u me....Oli.
Furious D
| posted on 21/9/06 at 06:50 PM |
Thanks to most for some helpful advice. I spoke to Tiger and they said it would probably need a bit of adjustment and it would be fine. (it is a
Tiger remote)
Went back to the seller and he has adjusted it and greased it up, says it is much better now, going back on Saturday to have another feel......oooooo
eeerrrrr
| posted on 23/9/06 at 08:11 PM |
Scott
We don't have that problem at all...
roadrunner
| posted on 24/9/06 at 06:57 PM |
Thats only cos you dont have reverse
