Author: Subject: Winter Project
TangoMan
posted on 3/10/06 at 10:21 PM Reply With Quote
Winter Project
I have been offered a 2.0 Zetec so will be swapping from a Pinto through the winter. I will aslo be going to Megasquirt and TBs.
I have been searching and reading so think I have covered everything.
Engine.
Lightweight flywheel (a steel one of eBay sounds good!!)
Clutch and bearing (Can I use the 2.0 ones?)
Spigot Bearing for end of crank
Starter of CVH.
Inlet manifold
TB's
M'squirt
Fuel pump and Surge Tank.
Exhaust manifold and system.
Modded alternator mounting
Modded water pump and water piping
Fabricate engine mountings
Shortened sump.
Have I forgotten anything??
I will also have a rebuilt, cammed 2.0Pinto for sale with R1 carbs and Megajolt complete with 4 branch manifold if anyone is interested. I will place this in the For Sale section once removed but anyone interested can see/drive it beforehand while it is still in the car.
[Edited on 3/10/06 by TangoMan]
Summer's here!!!!
JackNco
posted on 3/10/06 at 10:32 PM Reply With Quote
i may be interested in the carbs and megajolt setup depending on price as i dont need them yet. although ill probaly have the megajolt setup off u.
U2U me or call me on 07717174954
John
Some people are worried about the difference between right and wrong. I'm worried about the difference between wrong and fun.
O'Rourke, P.J. (1989), Holidays in hell. London (Picador)
Dusty
posted on 4/10/06 at 08:39 AM Reply With Quote
Might need a lifter pump to fill the surge pot depending on the position of the pot. To cut costs a mondeo 1.8L flywheel, pressure plate and driven plate can be used with a CTT133 (QH) release bearing. If you are going for more than about 150bhp then the mondeo clutch is a bit weedy and retro ford will redrill a 1.8 flywheel for an uprated pinto clutch and plate and this uses the pinto release bearing.
You will also need an oil catch tank plumbed to cam cover and block.
Narrow bodied starter off 1.8CVH or DOHC.
Inlet manifold could be fabricated for motorcycleTBs to save a bit of cash.
TangoMan
posted on 5/10/06 at 09:36 PM Reply With Quote
Have I read somewhere that you can have a pinto flywheel redrilled to fit a Zetec.
If so does this mean you can use the Pinto starter and clutch??
Summer's here!!!!
