Author: Subject: would all xflow twin side-draught manifolds be the same?
posted on 3/11/06 at 11:05 AM Reply With Quote
Just wondering is the angle of twin side-draught manifolds for crossflow be the same?
I have one on 1300 cc and there is just about enough room for the motorcraft distributor, but let's say hypothetically I put in a 1600; being taller, the carbs will foul against the bonnet so a manifold that is less angled or even horizontal would be better - is there such a thing?
isn;t the WWW wonderful? some research shows there are 2 manifold for the different capacity engines:
1300
and 2 falvours of
1600
the top & bottom are different - look at shadow on flange for cylinder 2
[Edited on 3/11/06 by 02GF74]
NS Dev
posted on 3/11/06 at 11:08 AM Reply With Quote
there are certainly a number of subtly different ones, made by different companies at various points in history but as for specifics, no idea, sorry!
Confused but excited.
posted on 3/11/06 at 11:51 AM Reply With Quote
I've got a new manifold in the garage. I'll have a look later and measure it to see if the flanges are parallel or not and the distance between them.
gazza285
posted on 3/11/06 at 02:42 PM Reply With Quote
There's loads. Different manufacturers had different angles and lengths, some came out fairly straight, some came out up and over etc. If clearance is a problem, you could take the manifold to shop with a surface grinder and have the head mounting angle ground to a different angle to increase clearance. If you are really bothered about running the carbs horizontal you can then have the carb side ground parallel to the head side as well.
