Author: Subject: Head off - how black should the pistons be?
smart51
posted on 7/11/06 at 06:55 PM Reply With Quote
I've just taken the head off my engine. Quite easy really, apart from the bolts being so tight that I bent my allen key through 50° before the bolts budged.
The valves all seem to be seated nicely and the gasket is in A1 condition.
How black should the pistons and combustion chambers be? There seems to be about 0.2mm of black tar fading to really dark brown by the edges. Is this OK for an 8 year old engine?
DIY Si
posted on 7/11/06 at 06:57 PM Reply With Quote
Seems fine. Wouldn't expect much different really. When you say the valves all seem to seat nicely, what do you mean?
Sun Tzu, The Art of War
Catpuss
posted on 7/11/06 at 07:09 PM Reply With Quote
With all the WD40 and stuff thats been put down those bores to get the thing going I wouldn't be supprised if its black and like tar
posted on 7/11/06 at 07:13 PM Reply With Quote
The only way to check for valve seating correctly is to remove them and check with engineers blue. Vacuum test and testing by pouring petrol/degreaser down the ports will test for leaks but will not be as reliable . Is it a black oily deposit or is it carbon caused by overrich mixture?
stevec
posted on 7/11/06 at 08:04 PM Reply With Quote
Checking them with blue is fine when they have been cut or lapped in, but unless a valve has been rotating regulary when running it may have a non uniform seat with a irregular contact area.
Steve,
[Edited on 7/11/06 by stevec]
posted on 7/11/06 at 08:15 PM Reply With Quote
In which case it's not doing it's job properly - sealing.
stevec
posted on 7/11/06 at 08:34 PM Reply With Quote
It can seal providing you dont fug with it.
posted on 7/11/06 at 09:30 PM Reply With Quote
Whats the point of having a valve if it doesn't seal? Try doing a cylinder leakage test with a valve thats not sealing!Compression test may not show up a leaking valve but it will cause an engine to run rough
smart51
posted on 7/11/06 at 10:29 PM Reply With Quote
Acetone down all the ports produces no leaks. OK, so they may not be gas tight, but its a good sign.
I put a bit of oil down the bores doesn't appear to leak. that said, the engine is on a slant and I only filled half way up the piston. I cleaned the mating surfaces with the acetone and in that time no oil seemed to leak.
posted on 8/11/06 at 08:25 AM Reply With Quote
Any signs of head gasket failure?
smart51
posted on 8/11/06 at 09:25 AM Reply With Quote
No, the gasket looks to be in great condition. The mating surfices of the head and block are fine and have cleaned up a treat. Even the oil that I poured into the bores last night is still there this morning. It all looks loveley.
posted on 8/11/06 at 11:13 AM Reply With Quote
Yep checking the valve sealing from the port side by filling it with a light solvent is a good test for checking the seal -- kerosene is easyiest cheapest to use as it dosen't evaporate quickly.
Another trick is to fill the port with kerosene and aim a jet of compressed air round the circumfrence of the valve, if you get bubbles it isn't sealing.
[Edited on 8/11/06 by britishtrident]
posted on 8/11/06 at 11:28 AM Reply With Quote
Mr Smart, just a thought. What exhaust system are you running?
If the primaries (or the secondary for a 4-2-1) for the middle two cylinders were partialy blocked it could cause the symptoms you are seeing, i.e. glowing headers, misfiring, lack of power etc.
smart51
posted on 8/11/06 at 12:08 PM Reply With Quote
I'll check the exhaust then. Now that the head is off I can get into the headers from both ends.
posted on 8/11/06 at 03:47 PM Reply With Quote
Check the valve clearances, tight tappets will cause problems/rough running etc
