adriane
| posted on 20/11/06 at 08:21 AM |
Speedo MK Indy Hayabusa
Help! Does any one know if I could use the drive flange connection bolts (which hold the the prop shaft to where the front sprocket used to be) for
pick up points for the speedo on a Hayabusa powered MK. I am using the original clocks. If not can you tell me what I would need to do in order to use
the clocks.
tks
| posted on 20/11/06 at 09:07 AM |
Yupsz
and then speedohealer or another electronic solution to alter the pulses..
Tks
OX
| posted on 30/12/06 at 01:29 AM |
i didnt think you could use the bolts because there in more of a rectangle bolt pattern rather than square,cant remember tho,its been awhile.thought
it might give an erratic speedo readout
