Author: Subject: Coolant Pipes
TangoMan
posted on 27/12/06 at 12:04 AM Reply With Quote
Coolant Pipes
I am about to plumb in the coolant pipes on my Zetec. I priced up all the elbows required.
Rather than have long lengths of silicon hose though, I thought it would be better to replace the straight lengths with metal tube.
I can find Stainless on eBay but not ally tube in 32mm (1¼ inch).
What has everyone else done??
Summer's here!!!!
soggy 3
posted on 27/12/06 at 12:31 AM Reply With Quote
I just used stainless.
bob
posted on 27/12/06 at 12:37 AM Reply With Quote
Put a search on ebay for "32mm tube and this came up among other things.
tube link
There seems to be a lot of 32mm hoover pipes about as well
theconrodkid
posted on 27/12/06 at 07:29 AM Reply With Quote
how much you need?ive got some mild steel chrome plated,welded up ok with the T pieces,rubbed the chrome down and painted it black.
bob you got first dibs on what i got left over btw
who cares who wins
pass the pork pies
Schrodinger
posted on 27/12/06 at 08:36 AM Reply With Quote
How about car builder solutions, they will put the bead on the end for you as well as make up T pieces if you need them.
I found them quick as well.
designer
posted on 27/12/06 at 09:05 AM Reply With Quote
Use aluminium tube, and be sure to bead the ends.
caber
posted on 27/12/06 at 09:07 AM Reply With Quote
What's wrong with copper plumbing tube?
Caber
RazMan
posted on 27/12/06 at 10:12 AM Reply With Quote
Another vote for CBS. They stock most sizes and will put the essential beads on the cut lengths for you.
Raz
martthefridgeman
posted on 27/12/06 at 10:58 AM Reply With Quote
i used a mixture of refrigeration copper pipe/fittings (available in large sizes and easy to work with) and aluminium tube from my local tv ariel supplier
JohnN
posted on 27/12/06 at 11:23 AM Reply With Quote
B&Q for Aerial poles, not sure of dia though.
TangoMan
posted on 27/12/06 at 11:32 AM Reply With Quote
Sounds like CBS is it then.
Thanks for the info.
Summer's here!!!!
thunderace
posted on 27/12/06 at 01:18 PM Reply With Quote
i did this it will shock you lol
£3.98
http://cgi.ebay.co.uk/Vacuum-Cleaner-StainlessSteel-32mm-Extension-Tube_W0QQitemZ230065976859QQihZ013QQcategoryZ43526QQcmdZViewItem
Jonte
posted on 27/12/06 at 02:31 PM Reply With Quote
is 32mm the prefered size for zetec cooling?
Click it
Jonte
Click it
bob
posted on 27/12/06 at 05:55 PM Reply With Quote
jonte
Large exit from thermo house is 32mm and polo rad outlets are 32mm as well,the rest is normally 19mm unless you want to try and force something smaller on
DIY Si
posted on 27/12/06 at 05:58 PM Reply With Quote
I've used some nice chromed copper pipe from B&Q before. Cheap, looks nice and smart too. I've not ever beaded the ends, but equally, never had one fall off.
Sun Tzu, The Art of War
zetec
posted on 27/12/06 at 07:25 PM Reply With Quote
I'll second plated copper tube. Local plumbers is a great source of parts for fuel lines as well...4 years on and few 000s miles and still all as good as new.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
