Author: Subject: thread size of x flow oil pressure sender
donut
posted on 29/1/07 at 03:40 PM Reply With Quote
As above , what is the thread size for the oil pressure sender for a X flow?
flak monkey
posted on 29/1/07 at 04:35 PM Reply With Quote
If its the same as a pinto it will be 1/4NPT if i remember rightly.
Sera
http://www.motosera.com
posted on 29/1/07 at 05:27 PM Reply With Quote
if it is the same as the water temp sensor, then I can measure it (I reckon it is 1/4 NPTF).
flak monkey
posted on 29/1/07 at 06:52 PM Reply With Quote
Water temp senders are usually 1/8npt on ford engines.
Remember with NPT threads the OD of the thread has nowt to do with the stated size of the thread. A 1/8" NPT thread actually measures 13/32" (0.405" OD) a 1/4" NPT thread measures 35/64" (0.540" ). Its related to the bore size of the pipe the thread was originally designed to be cut on.
David (bringer of much random info)
[Edited on 29/1/07 by flak monkey]
Sera
Deckman001
posted on 2/2/07 at 08:06 PM Reply With Quote
Cheers guys, it is 1/4 npt whatever thingy I'll try to get the new tee fitted this weekend
Jason
