Author: Subject: Redtop onto Omega gearbox
Russiow
posted on 3/3/07 at 10:29 PM Reply With Quote
Just to let you all know how it all went!!
Tested racer today at the farm..
Redtop with flat flywheel onto Omega gearbox.
Used a Omega clutch and spaced the slave out 20mm with a turned up adaptor.
The engine has the Omega sump on it and an oil coller. I filled it with the right amount oil from a measuring jug.
It still seemed to puff a little of smoke.
Do you think the oil level needs reducing??
Russ
martthefridgeman
posted on 3/3/07 at 10:31 PM Reply With Quote
did you fit the windage tray / baffle between the sump and crankcase. mja
Russiow
posted on 3/3/07 at 10:38 PM Reply With Quote
Yeap she is in there...
Sandwiched between sump and block
MkIndy7
posted on 4/3/07 at 02:14 PM Reply With Quote
I'd give it a while to all warm up etc...
After they've been stood for a long time there notoriously rattely etc.
Hope the smoke aint oil on the Exhaust Downpipe, the XE sumps are a nightmare to get sealed!
Russiow
posted on 4/3/07 at 04:05 PM Reply With Quote
The sump has sealed fine I used the rubber style gasket.
I have done the rocker cover mod and run the large brether to a catch tank.
I don't know if it makes a difference??
It has been sat for at least a year, i did the head gasket and cam belt etc
Any ideas to the smoke??
ned
posted on 4/3/07 at 08:38 PM Reply With Quote
valve stem seals?
beware, I've got yellow skin
Stu16v
posted on 4/3/07 at 10:14 PM Reply With Quote
You should fill it according to the dipstick - NOT to the measuring jug. It might make a difference...
Russiow
posted on 4/3/07 at 11:09 PM Reply With Quote
Stu please explain your reason behind this??
As I have fitted a Ecotec sump from an Omega which is basically the same engine.
I have filled the engine with correct amount of oil as per Haynes manual.
My reason for this is that the XE dip stick is in a different postion to the ecotec therefore could read different with the omega sump.
Hope I make sense...
Russ
MkIndy7
posted on 4/3/07 at 11:45 PM Reply With Quote
I had to change mine to the rubber style gasket and baffle plate.
From the online guide I had it mentioned that part of the 8V Baffle plate needed removing to match the original XE's baffle plate clearance... I just can't remember if it turned out the same or it really did need modifying
It might be worth checking if you haven't already done it.
stevebubs
posted on 5/3/07 at 12:20 AM Reply With Quote
Russ
Surely the dip stick tells you where the top of the oil is relative to the crank. Overfilling past this point can lead to crank whipping up the oil in the sump.
I had this trouble as I have chopped my zetec sump right down and tried overfilling slightly. Result was the oil getting whipped when running.
Reduced the oil down to almost dipstick max level and problem went away.
