Simon
| posted on 16/3/07 at 09:07 PM |
Wanna laugh
Phoned the Audi shop as I need some gaskets and hoses etc for my turbos.
They sent a fax of exploded view of twin turbo layout, and I asked for prices for two oil feed pipes and return pipes. Same again for water pipes, a
stud for one of turbos and both sets of exhaust gaskets.
Price £374
Phoned and said I'd give it a miss (though I'll have gaskets and exhaust stud. Then I mentioned I'll have 8 banjo fittings and
bolts/washers and make my own pipework. OK came the reply.
Five minutes later they rang back.
"Er the banjo fittings are £31 each" Yeah times 8.
So not only was first price extortionate, the also underestimated by £240. Bill would have been over £600 for a bit of pipe and fittings.
Can amyone recommend a good, reasonably priced supplier of banjo's and fittings.
Cheers very much.
Simon
[Edited on 16/3/07 by Simon]
paulf
| posted on 16/3/07 at 09:13 PM |
I would look in the yellow pages for local industrial hydraulic enginners.They should be able to provide everything you need and much cheaper than
motorsport orientated suppliers.
Paul.
Confused but excited.
| posted on 16/3/07 at 09:25 PM |
'Frailers' in Church Street, Runcorn is good for Banjos. Also Guitars and amps. Ask for Frank.
bob
| posted on 16/3/07 at 09:43 PM |
Simon
http://www.thinkauto.com
Think automotive are in isleworth and have a good stock of parts,i've used them a few times.
[Edited on 16/3/07 by bob]
Simon
| posted on 16/3/07 at 09:50 PM |
Paul,
That's the second time I've heard that today My local friendly m/factors recommended a place not 10 mins from home.
Confused,
I think you
Bob, Used them myself, and will try if local hydraulic place can't help.
Cheers chaps
Simon
stevec
| posted on 16/3/07 at 10:01 PM |
Try here. Enter banjo in the search box.
Steve.
http://store.norgren.com/UK/en-GB/Search.aspx
[Edited on 16/3/07 by stevec]
Volvorsport
| posted on 16/3/07 at 10:41 PM |
my local hydraulic place make my oil pipes too , swaged with the correct fittings on for about £25 .
banjo fittings are about £3 each .
youll find most are equipped for BSP and have to order metric stuff .
i do have some BSP/NPT fittings i intended to use for my return if you get stuck .
www.dbsmotorsport.co.uk
getting dirty under a bus
jambojeef
| posted on 16/3/07 at 11:39 PM |
You'll know this but just a reminder that if its oil hoses you are after - the oil leaving the turbo will be hot - possibly over 150 degrees and
so the hose that you spec will need to have a high temperature liner.
The high temp silicone hose is a good bet - some are stable up to 250 degrees
Post some pics up of this beastly conversion then!
Geoff
mark chandler
| posted on 17/3/07 at 09:31 AM |
Hi Simon,
I guess you have specific sizes in mind, classic range rovers have banjo's on the axle breathers, I,m sure I can find some of them for free.
Another thought is get some goodrich brake hoses with banjo ends fitted.
Regards Mark
RazMan
| posted on 17/3/07 at 11:04 AM |
My local hydraulic stockist rescues me in times like these. Usually easier if you have a pattern to wok to but often you can just do a sketch of what
you need and they will come up with something a fraction of the price.
Raz
Simon
| posted on 18/3/07 at 12:20 AM |
Mark,
I went to our local hydraulic chap today (does tractors, so about the right technology for the old Rover V8 , and he'd gonna contact his
suppliers Monday and give me prices.
Cheers for all your suggestions.
Simon
