simonknight
posted on 10/8/03 at 06:14 PM |
clutch not engaging
4
hi guys ,i need some help completly out of ideas for this now. i can select gears ie 1st gear with engine running as it goes into gear the car jumps
forward and engine dies ive stripped the clutch down 3 times now thinking it might be stuck ect cant see anything wrong with it .ive measured the
plates to make sure im putting them back right tryed both sets of clutch springs ive even tried selecting first engine of working the leaver manually
and it still rocks back and fourth the the lever in.
the only thing i can see is that the clutch pushrod goes through the clutch has quite a bit of movement in it ie back and fourth please help ..
Stu16v
| posted on 10/8/03 at 09:09 PM |
Welcome Simon. Hopefully one of us can help out, but we could do with a bit more info. I'm guessing it is a bike engine you are using. If so,
what type engine (blade??)? Has it always had this problem? Have you changed the clutch?
| posted on 10/8/03 at 10:07 PM |
try starting it in first with the clutch fully in, if it jumps then the clutch is definitly not disengaging (you probably new that, but hey, all
good!)
then maybe try actuating the clutch with it all open (equvilent of the g box or bell housing off if it were a car engine) and see where the give is.
Someone who knows bikes will undoubtedly help!
does the clutch pedal have any resistance in it? u know, does it feel like you are moving the spring?
[Edited on 10/8/03 by JoelP]
type 907
| posted on 10/8/03 at 11:10 PM |
You have discribed clutch drag, i.e. clutch not disengaging. We don't know what engine it is;
SO WILD GUESS
Ball bearing missing at end of clutch pushrod. (fell out during stripdown)
Sorry if I'm wrong.
Too much is just enough
Rorty
| posted on 11/8/03 at 06:31 AM |
Did this just happen all of a sudden, or did it transpire after you had fiddled with the clutch?
Perhaps, as type 907 says, the bearing fell out when you were fiddling with it.
The cable may have dislodged itself at one end or the other.
Is the cable new? Perhaps it has stretched. What adjustment have you got on the cable? Is it properly adjusted?
Perhaps a homemade cable support bracket has bent.
Things don't just go wrong, there's always a reason. Try tracing back the problem/your interference.
Cheers, Rorty.
simonknight
| posted on 11/8/03 at 03:38 PM |
re clutch not engaging
Text
hi guys
it is a fireblade 919cc think it come out of a w reg bike , ive stripped it down have had the friction plates checked over seem to be o.k the bearing
is in the pressure plate i no wat u mean it easily falls out .
the engine has been installed a while but ive only just got to the stage of test driving it ,ive tried moving the lever on the end cover it feels like
its connecting to the push rod has some resistance but i can move the lever with my thumb thats how easy it is to the fully engaed position .
the cable is a new custom one i had made ive got it disconnected at moe trying to get it to work at the lever first
many thanks everyone
simon
