<<  1    2  >>
Author: Subject: Help Needed - Cylinderhead
posted on 15/4/10 at 01:58 AM Reply With Quote
Imbalanced throttle bodies will easily cause this since the fueling can't be correct for every throttle body if they are opened different amounts. The one you are getting flames back through is probably running very weak.
Can't be incorrect cam timing on a single cylinder unless the camshaft has somehow been twisted!
<<  1    2  >>
