<<  1    2  >>
Author: Subject: Twin engines
posted on 12/12/05 at 11:54 AM Reply With Quote
This thread is the best leg pull I have ever read. 1 pinto is bad 2 is just funny farm stuff.
Even if it could actually move under its own steam an out the box Rover K16 1.8T 180ps engine would more power at the wheels for 1/4 the weight.
If you want a straight 8 buy a Rolls-Royce B81 alloy engine from an airfield fire tender.
Time to get back to the real world .
[Edited on 12/12/05 by britishtrident]
liam.mccaffrey
posted on 12/12/05 at 12:20 PM Reply With Quote
the power transmitted by friction belts belts is proportional to both the coeff. of friction (between pulley and belt) and the tension on the tight side of the driving pulley. So assuming you had a belt strong enough you could transmit any power you want. for v belt pulleys there is modification to the coeff. of friction to allow for the pulley geometry, and for toothed belt its entirely down to the strength of the belt used
all in belts can transmit any amount of power you want by either having strong or multiple belts
Build Blog
Build Photo Album
caber
posted on 12/12/05 at 01:41 PM Reply With Quote
British-Trident,
Oh well I suppose that means I need to get a new user name before anyone takes me seriously in future I suppose I also need another name to try another wind up sometime
Caber
posted on 12/12/05 at 03:00 PM Reply With Quote
Problem comes with the massive cantilever loads on the pulley shafts, Morse hy-vo chains are a better bet in automotive drive situations, they worked pretty well in the old 1800 Landcrab automatic and the original Olds Tornado.
tks
posted on 12/12/05 at 08:45 PM Reply With Quote
anyway
chaindrive is an better purpose offcourse it will make noise..
Any way its logically that belts can drive 500BHP but offcourse we didn't had the room for it, also an belt needs tension, and tension results in strong bearings...etc..
anyway don't build an car for 2 pinto's is the conclusion ok?
Build it with 2 rovers K8 or just one Ally V8
atleast my 2p(euro cents )
Tks
stevebubs
posted on 12/12/05 at 09:52 PM Reply With Quote
Originally posted by jon_boy
There was a nove running two xe turbo vauxhall lumps, one front one rear (search for boost beast in goolge it may find it) and that was very rapid if a wee bit hard to set up
dubsport twin-engined VWs were done in a similar fashion
<<  1    2  >>
