| posted on 28/4/06 at 01:33 PM |
quote: Originally posted by ned
I also plan to put small drillings into the pulleys and rocker cover as a more permanent mark than just paint so want it to be right.
no, not drillings; use a hole punch to mark it ; that way you don't remove any metal (ok, it isn't gonna upset the balance bit time but
NS Dev
| posted on 28/4/06 at 02:29 PM |
Ned, I cut a piece of the old rear belt cover off with the bolt hole nearest to the tdc pointer attached to it and bolted it back onto the oil pump,
so I still have a pointer with no rear cover.
The vee pulley on the front of the engine may not be keyed but will only go on in one position, it has vernier holes just like the flywheel does.
givemethebighammer
| posted on 28/4/06 at 03:31 PM |
Cheap dial gauges here
http://www.chronos.ltd.uk
and for the record if you unscrew the tip from the dial gauge a mountain bike spoke will screw back in in it's place. Simple cut the spoke and
file the end off round for a long reach gauge.
[Edited on 28/4/06 by givemethebighammer]
| posted on 28/4/06 at 06:08 PM |
Marks reply about the bolt welded to an old sparkplug works a treat. Have used this method several times
