<<  1    2  >>
Author: Subject: Polo rad
poloace
posted on 15/4/03 at 10:50 PM Reply With Quote
Polo rads are this is my area of experince! I'm on my 5th one,
The mk1 & mk2 are smallest most compact a mk3 has small mounting pegs that would get in the way. Also MK3 GT is bigger . Some Mk2 have an intergral header/fillar cap on one side but for a locost application they will be to low to be used.
Very light and in my experience not that leaky.
dutchsuperseven
Builder
Posts 105
Registered 28/2/03
Location Born, Holland
Member Is Offline
Photo Archive Go!
Building: Locost-clone, powered by zetec 1.8, sierra type N9
posted on 19/4/03 at 07:00 PM Reply With Quote
Polo radiator
Me, myself & i used a golf mk2 radiator (1.3 1984?) in my machine. There should be a pic. in my photo archive. It fits well and the schrouding even accepts a ford fan.
posted on 20/4/03 at 04:32 PM Reply With Quote
Eddy (and everyone else)
Panic over! I managed to swap my original wide Polo rad for a narrow one, VW part no 86712125 3E. This is the 470 x 330 x 50 sized one.
I've been annoying my neighbours this afternoon, angle grinding off my old brackets. I'll work out the new ones tomorrow, weather permitting.
Incidentally, I compared the size of the original Escort rad with this one - the Escort one has roughly 300mm x 20mm extra surface area, but the Polo one has a lot more pipes in it. I expect the Polo one to be more efficient!
rgds,
Oops! One more question - what fasteners were originally used to hold the rad? I can see the holes in the plastic, and I guess that they used fairly large self-tapping screws. Is this correct?
[Edited on 20/4/03 by David Jenkins]
Fast Westie
posted on 22/4/03 at 11:49 AM Reply With Quote
I tapped mine out to M6
The car in front is a Westfield
Northy
posted on 26/8/03 at 02:12 PM Reply With Quote
Sorry to drag up another old post, but I'm just about to sort the cooling out with one of these rads.
How does it all plumb together? Do I need a seperate header tank? If so where do I plumb it into? I'm not using a heater, so that should make it a little easier.
Graham
ned
posted on 26/8/03 at 02:18 PM Reply With Quote
Northy,
I know its for a 16v (but shares the block as 8v) but SBD have a diagram on their site of the plumbing for rad, header tank etc. wonder if it's of any use to you?
Ned.
beware, I've got yellow skin
Northy
posted on 26/8/03 at 03:39 PM Reply With Quote
Ned, be a good chap and put it on here!
PS You'll have U2U in a mo.
Graham
ned
posted on 26/8/03 at 03:41 PM Reply With Quote
sorry, it's a bit on the large side, but you did ask!
Ned.
Northy
posted on 2/9/03 at 02:34 PM Reply With Quote
Sorry to drag this up yet again...
Could someone with a Polo rad tell me what connections it has on it? Is it just a large one at the top and bottom? Any other smaller connections? And could they also be so kind as to tell me the diameter of them?
The problem is I have a chance to get some decent silicon hoses at the weekend, but won't have the rad by then.
Graham
Mix
posted on 3/9/03 at 07:36 AM Reply With Quote
Rad has only two hose connections, both on the same side, one top and bottom, outside diameter 32mm, (this is the diameter of the pipe not the retaining bulge).
Mick
Northy
posted on 3/9/03 at 09:09 AM Reply With Quote
Bless you! Which side are they on? Can the rad be fitted 'upside down' so to speak?
Graham
eddymcclements
posted on 3/9/03 at 01:36 PM Reply With Quote
My Polo rad (see further up in this 5-month-old thread for details) has 32mm top and bottom connections on the near side of the car. It also has a small take-off for a bleed hose at the highest point of the rad on the same side. I can't see any other was of ensuring air is expelled other than by utilising this connection.
Eddy
eddymcclements
posted on 4/9/03 at 11:01 AM Reply With Quote
I thought I'd already posted this link to my radiator in which you can see the small bleed hose. Not connected to anything in this photo, though.
Eddy
<<  1    2  >>
