<<  1    2    3  >>
Author: Subject: turbo diesel powered locost
UncleFista
posted on 22/3/02 at 01:40 PM Reply With Quote
The 2.3 N/A Ford Diesel is a big, heavy, laggy, underpowered slug of a powerplant. If you wanna fit a Diesel, fit a turbo-diesel, you'll regret it if you don't
(I once drove a 2.3 D Sierra, never again...)
Tony Bond / UncleFista
Fatboy Dave
posted on 22/3/02 at 02:00 PM Reply With Quote
No. No no no no no no no no. NO!
That horrible, wheezng Peugeot 2.3 lump is awful. Made of cast iron it weighs a ton, produces a whopping 63bhp, and doesn't even have a turbo. It also makes enough noise to wake the dead.
What you could do though, because the 2.3D Sierra was a s desirable as stinging nettle underpants and about as usefull as a donor, is buy it for the diesel spec gearbox and differential, as you need to choose these with care if you are getting them out of a petrol car (the diff has to have roughly a 3.09:1 ratio)
Dave
James
posted on 22/3/02 at 03:53 PM Reply With Quote
As I said I've no desire particularly for a diesel- if nothing else I'm a bit dubious about the health implications for diesel emissions- what with them being carcinogenic and all. I may be wrong but aren't they meant to give out some pretty nasty fumes compared to petrol engines (not that they're good- just not quite as bad!). I guess modern Diesel's from the likes of BMW and VW are a lot better though maybe?
Why would the 2.3D gearbox be better though? Just because of the ratio or something else?
James
Fatboy Dave
posted on 22/3/02 at 04:00 PM Reply With Quote
They are, they're bl**dy lethal the fumes. It's all the cetane, and the fact that the third most cancerous compand known to man is found in diesel fumes (3nitrobenzantrone IIRC, but it's probably wrong).
As for the diesel box, yes, it's purely for the ratios. No point buying the first gearbox that comes along if the ratios are wrong for the engine. Sierras/Sierra parts are two a penny, and it's no real hardship turning stuff down.
Dave
phil
posted on 8/8/02 at 09:57 PM Reply With Quote
Well boys , just got myself an FSO g/box from the scrappies today, looks like it will fit on to the citroen tdi no prob.Even the citroen clutch plate fits the FSO splines.The only problem at the mo is that the output flange is of the rubber doughnut type (fixed, non sliding), like the older fiats & lada i think. The question is what type of propshaft layout do i use?, do i use the doughnut instead of a u/joint. all ideas welcome
cheers PHIL'''''''''
paulbeyer
posted on 8/8/02 at 10:54 PM Reply With Quote
I've been playing with the idea of using a TD engine in mine, mainly as a cheaper mode of transport to and from work. I'd planned to use either a VAG TD or a Rover TD. Both power medium sized cars yet still return 55mpg combined with approx 10s 0-60's, think what that'll be in a locost!
If you're after cheap motoring how about LPG? I've just spent 2 days converting my Saab 9000 to run on LPG and although it is early days it runs smoother, quieter and at 34 pence / litre compared to 78 pence a litre for diesel a lot cheaper.
rallyslag
posted on 14/8/02 at 05:33 PM Reply With Quote
As for fumes and running costs you should also look into running your car on biodiesel
very very cheap and easy to make and has none of that carcanagenic crap from petrolium diesel
have a look on http://www.veggievan.org/
the book from there is highly recommended (i got mine from amazon.co.uk)
Old chinese proverb: "If a man speaks in a forest, and no woman hears him, is he still wrong?"
Macca
posted on 14/8/02 at 05:42 PM Reply With Quote
Is this stuff legal as no taxes are payed?
What are the ministry likely to say if used on public highway?
Col.
Fatboy Dave
posted on 14/8/02 at 05:44 PM Reply With Quote
It's a grey area biggfer than Johnnie Major.
Technically, *any* fuel that can propel a vehicle on the highway is liable to duty, even if you have a car that can run on tap water.
However, actually, trying to pay duty that isn't automatically collected at the pumps is almost impossible....
Dave
Stop the planet, I want to get off
phil
posted on 15/8/02 at 06:05 AM Reply With Quote
When i get it running ok and get a respectable speed from it , i just might have a look now you've put that idea in my head.. cheers phil...........
JohnFol
posted on 15/8/02 at 11:03 AM Reply With Quote
One of the early comments was about using a VAG diesel.
I consiously chose a diesel a few months back having had 330 BMW's, 2.5 Vectra's ./ . .
I have a Golf 150bhp diesel GTi , and it's faster than their 150bhp petrol GTI, with a 0-60 of around 8.5 (however the petrol is in 2nd I'm already in 3rd. Six speed box. I also get 236 lbft torque (more than Boxter S), lower tax and insurance and a combined mpg of 54.
So, I am a diesel convert and would recommend it. Mind you, when did common sense fit into a forum about makign a car from piles of steel?
rallyslag
posted on 12/9/02 at 06:58 AM Reply With Quote
you can pay duty on your biodiesel now and its at a reduced rate of 21p/liter
plus you wouldnt have to pay any tax on your fuel for use on the track
B@man
posted on 21/10/02 at 08:53 AM Reply With Quote
Phil, Hows the conversion Going ? I' want to fit my Rickman with a Ciroen TDi Lump so I am very interested in how this is going. Out of interest Does the FSO Gearbox have a un-boltable bell housing or is it integral to the Gearbox ? - I'm wondering if I could make an adapter plate to fit between the FSO bell housing and the T-9 box, thus solving the Prop problem
Projects :
Robin Hood S7 - Deceased !
SSC Stylus 16v - Sold
Spartan Zetec conversion
Rickman 2.0 Petrol (New Engine) - Sold
Rickman 1800 TD (ongoing)
TVR 400SE (Nearly a kit ?)
phil
posted on 21/10/02 at 07:36 PM Reply With Quote
problems encountered so far.
Hi B@man,
Thanks for asking,the locost TDI is going quite well at the mo. Yes the bellhousing is removable from the FSO g/box, so you may be able to fit another box of your choice. I've decieded to keep the box for the moment as it looks quite good and has good ratios for the TDI & escort diff. The propshaft was easy to shorten and all i had to do was make a mounting for the centre bearing in the trans tunnel,both sections were shortened and i've retained the output doughnut, mounting the center bearing at the correct height to keep the front section of the shaft level.
As the TDI was mounted at a slight angle the g/box also sits at a slight tilt(should not be a problem). As mentioned earlier the BX clutch plate fits the g/box splines
but i will need to make another spigott bearing as the shaft is smaller than the f/wheel brg on the TDI. Also had to make a remote gear linkage (because the lever was under the scuttle). Hope you understand all this waffling and that it may be some use to you.
regards Phil.........
JohnFol
posted on 22/10/02 at 08:00 AM Reply With Quote
I know I've joined this posting a little late, but I drive a diesel, by choice and would recommend it to anyone. 1 proviso, get a high pressure version , ie BMW 330D, or VAG 1.9 TDi (my one).
150bhp / 236 lb ft. Forget LPG. Yes it is much cheeper than diesel, but it gives less mpg than petrol.
Dunc
posted on 22/10/02 at 09:26 AM Reply With Quote
One downside of a diesel is the low revving ability. It may have more torque than a petrol engine but by the time it goes through the higher gearing the torque at the wheels could be much lower. I do agree that they are definately worth looking into but the german variants are expensive, I've been looking at the rover TD, equivalent in performance and MPG to the VAG's but cheaper and quite possibly lighter.
B@man
posted on 22/10/02 at 04:25 PM Reply With Quote
Phil, Thanks for the Response, I think the TD option will have to wait on cost grounds, I found a FSO gearbox but the yard want £150 ex VAT for it and the cheapest I could find a TDi engine was £500 exvat, for that outlay I can probably rebuild the complete car !
I nearly had a Ford (yuk!) Sierra TD engine yesterday, the complete car was going for £200, but sadly someone had tried to fit mondeo Injector pipes in the wrong order so It would'nt run !
So the current plan is to stick with the 1800 pinto (if it will start after 3 years of being stood near the coast).
Projects :
Stu16v
posted on 23/10/02 at 05:14 PM Reply With Quote
There is another gearbox that will fit the Pug/Citroen TDI engine. Its the R380 gearbox which is fitted to the latest Ley/Daf 200 vans, they have an n/a Pug motor as standard.
paulbeyer
posted on 23/10/02 at 10:54 PM Reply With Quote
Jon,
A little bit about LPG. You are right, it does give less MPG than petrol (typically about 5%-8% less) due to the fact that LPG has a slightly lower calorific value than petrol. My Saab 2.3 used to give about 28mpg on unleaded at a steady 80mph and now returns 25.4mpg on LPG. Unleaded used to set me back about 78.4 ppl, LPG now costs me 30 ppl. I'm sure you can see the immediate cost benefit even taking into consideration my lowered MPG figures. LPG also has a higher octane level typically 110. It also burns slower than petrol, producing a smoother and quieter running engine resulting in less wear. At my first service since converting to gas my used engine oil was still yellow and translucent, partly due I suppose to the fact that my emmisions are now greatly reduced.
Carbon Monoxide reduced by 75%
Nitrogen Oxides reduced by 40%
Nitrogen Dioxide reduced by 80% (over diesel)
Carbon Dioxide reduced by 10%
Ozone reduced by 87%
Hydrocarbons reduced by 85%
Particulates reduced by 99% (over diesel)
It is also said that there is a reduction in performance once converted to LPG but I have not found this to be the case. Each fuel type has its good and bad points and having owned many petrol and diesel engine cars I am mightily impressed with LPG. How else could I run a Saab 9000 2.3 for the same sort of cost as a Pug 205 Diesel? I have both on my drive and the Saab wins every time.
B@man
posted on 24/10/02 at 08:19 AM Reply With Quote
Re LPG.
OK it's cheap now, but once it catches on in a big do you think the government will keep the duty on LPG fixed ?. When Diesels where not as common there was a lot less duty on the fuel than there is now. As soon as the is a large number of LPG powered cars on the roads the government will have no option but to increase tax on LPG if only to offset the losses made in the decline of unleaded sales. I suppose the only way to know is to wait see.
Meanwhile I'm going to safeway's to fill my TD mondeo with sunflower oil.....
Projects :
paulbeyer
posted on 24/10/02 at 09:09 PM Reply With Quote
Yup, you're probably right, LPG price hike are almost inevitable. One of the reasons duty is so low at the moment is because the present government are committed to cutting green house gasses and LPG is one cheap and painless way for the government to be seen to be doing that. It wont last, as you quite rightly point out but I intend to make hay whilst the sun shines.
interestedparty
posted on 25/10/02 at 02:02 AM Reply With Quote
Can't see how LPG reduces greenhouse gases.The one that's at the heart of fuel use is carbon dioxide. By the figures given above CO2 is only less than petrol by little more than the decrease in power, and that's easily compensated for by using 10% more throttle
John
paulbeyer
posted on 25/10/02 at 02:01 PM Reply With Quote
Sorry, for greenhouse gas read pollution.
I'm going back to building my unleaded petrol powered Indy now.
phil
posted on 26/10/02 at 07:40 AM Reply With Quote
but don't the profesional hay makers run their machines on stuff called diesel???
regards phil....
interestedparty
posted on 26/10/02 at 09:35 AM Reply With Quote
regards phil....
That's a good point. I think it's really funny when I see programmes on TV extolling the virtues of growing renewable energy sources like rapeseed oil for running buses and stuff on, when all the ploughing and harvesting is carried out by diesel powered machines!
John
<<  1    2    3  >>
