Author: Subject: Water Pump Zetec
prelude1980
posted on 9/11/08 at 04:50 PM Reply With Quote
Water Pump Zetec
Anyone know if you can cut the impeller off a blacktop water pump, so that the pulley will still work.
I'm fitting an electric water pump an need to remove the mechanical pump but still need the pulley in place
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
posted on 9/11/08 at 06:07 PM Reply With Quote
I think the impeller will come off as there is a one that can be put in so goes round the same as the crank pulley.
May just be pressed on.
